Question about Rheem Paloma Tankless Water Heaters PTG-74PVN Tankless RTG-74PVN
I have a paloma ptg-74pvn and the digital temp. display keeps shu
I have a paloma ptg-74pvn and the digital temp. read out keeps shutting off and the water goes cold pls if any one knows what i can do to fix this let me know.
    Problem Solver:
  • 13 Answers
How reliable is your AC? With the digital r/c connected, every time the heater recovers from power outage it's in the OFF default state. If you can not fix the power issue, disconnect the remote control. The w/h will recover in the ON state.
Posted on Feb 12, 2010
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
Indoor Paloma water heater showing error message C2 31 - there is no hot water. Any idea? Model #: PTG-74PVN
that is the water inlet temperature sensor fault.. check and clean scale from sensor or have it replace by a qualified technician
Jul 18, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My paloma tankless water heater will shut off in the middle of a shower
I am not sure if this is it but I had mine at too high of a temperature therefore I was not using enough volume of hot water to keep the heater on. They have a minimum amount of flowrate to sustain. Try turning the water temp down to 125-130. Hope this helps
Jan 27, 2010 | Rheem Paloma Tankless Water Heaters...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
PTG-74PVN
I suggest you call tech support. I had a similar problem, and after walking me through a few tests, they determined it was likely a motherboard problem and are sending a new one. At 2 1/2 years, your unit should still be under warranty...
Sep 01, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
May 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma  Tankless Water Heaters PTG-74PVN  Tankless RTG-74PVN Logo
256 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
