Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenimore portable washer
My washer was working fine then all the sudden it stoped draining properly it washes and spins fine my husband and i turned it up side and we noticed there are two black like sticks and he seems to think that one of them is broken does any one have any idea what that is and if it would make my wahser not properly drain any help would be great. thanks
aomee
  • chenzhenhe Jun 25, 2008
    In my case, it stopped for draining and those LEDs flashed. After I pressed start again. Draining went on and was followed by spinning. After finished this cycle, manual pressing start needed. Not annoying.
Ok" sounds like motor coupleing is broken
coupling is attached to motor
coupling can be replaced, you will see if you turn the motor
by hand that it's broken
make sure the power cord is not plugged into wall
take coupling and make and model of washer to
appliance parts store or order thru sears parts
Posted on Jan 22, 2008
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Washer not agitating,spining,motor turns but will not turn belt,the belt gets hot an melts.Replaced belt,lid switch works ok, I can manually turn agitator in clock wise direction but not counter clock...
Need model number! Do a google search for a manual (just search by model number). Repair parts and some troubleshooting help at: http://www.repairclinic.com/
Jan 16, 2014 | Washing Machines
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
Washing machine wont drain
Does the washer spin when in spin cycle ? If it does spin and there is no water coming out of the drain then you most likely have a bad wa
Aug 07, 2012 | GE Washing Machines
Displays PFE
The washer will stop during spinning .
Spinning is insufficient. Error display PFE
Is the filter of the drain pump clogged?
Is the drain pump operated?
Did you use the proper amount of detergent?
Is the drain hose placed higher than 1m above floor?
Mar 11, 2012 | Washing Machines
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
93 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
