Question about Crosley CAWC529JQ Top Load Washer
My washing machine will not rinse or spin in any mode
  • Crosley Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinemy washing machine will not rinse or spin in any - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 03, 2010
My washer fills with water but then does nothing lid switch is good
Posted on Nov 19, 2012
Joe_Rex
  • 114 Answers
SOURCE: F&P smart drive 601 washing machine will not advance from wash mode
ALL WASHERS HAVE A LOADING DOOR SAFTEY SWITCH ... THEY ARE THER TO PREVENT CHILDREN FROM STICKING THERE HAND IN THERE WHEN THE WASHER IS IN THE AGITATING OR SPIN CYCLE. WHEN THEY GO BAD OR STICK, THE WASHER WILL FILL AND THATS ALL ... THESE SWITCHES ARE USUALLY INEXPENSIVE BUT CAN BE A REAL PAIN WHEN THEY GO BAD. START THE WASHER WITHOUT CLOTHES IN IT AND LET IT FILL ... OPEN THE LOADING DOOR AND SEE IF YOU SEE A SMALL HOLE AROUND THE INSIDE OF THE LID OF THE WASHER ... NOT ON THE DOOR. IF YOU FIND IT ... TRY STICKING A SMALL UNBREAKABLE OBJECT THAT WIIL FIT INTO THE HOLE. MAKE SURE YOU WILL NOT LOSE GRIP OF THIS OBJECT FAND HAVE IT FALL INTO THE HOLE. THEN GENTLY PUSH DOWN ON THE SWITCH BELOW A COUPLE OF TIMES AND SEE IF IT WILL BEGIN TO AGITATE ... SOME NEWER MODELS HAVE THE SAETY SWITCH BUILT INTO THE HINGE ON THE DOOR. THESE SWITCHES ARE NOT EXPENSIVE SO DONT GET RIPPED OFF.
Posted on Apr 29, 2007
  • 185 Answers
SOURCE: Brandt washing machine gets stuck at rinse
check the coupler it might be the timer
Posted on Mar 25, 2008
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
The machine will not spin only without doing a wash. How to fix that???
Most machines will do a spin mode even though it does not state it you have to set to a final rinse and spin mode.
good luck
Feb 25, 2015 | Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Have kenmore heavy duty 80 series about 15 years old. It will not go into spinning mode after washing mode or rinse mode as it is supposed to.. By fooling with the controls I can eventually get it to...
Problems with a washing machine not spinning or not draining are often inter related..
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2010 | Kenmore Washing Machines
Hello, I have a F&P Smartdrive 5.5 Excellence washing machine. Am I able to reduce the amount of rinses it does? It appears to be performing 2 rinses and I would like to cut it down to one only as we...
Hi just read your posting.Now the 1st rinse cycle is always a spray rinse when the machine is set at the factory.If you follow these instructions then the 1st rinse will be a short spin only,with no water usage.1---Select the OPTION ADJUSTMENT MODE by pressing and holding the START/PAUSE button, then pressing the power button.Then release both after about 2 seconds. 2---Press either SPIN SPEED button to turn on the SLOW light,which is the spin only mode on the 1st rinse. 3---Once the SLOW button is lit push the POWER button to return the machine to normal mode again.Hope this helps and please reply back to let me know how you got on.We are on tank water too but thankfully we have a good bore.Looking forward to your reply and good luck.
Jul 11, 2010 | Fisher and Paykel Washing Machines
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Spin Issues
Get manufaturer out under waranty,proberly moduale
Oct 11, 2008 | Washing Machines
Crosley CAWC529JQ Top Load Washer Logo
1,008 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
