I have a wrt54g v8 router. Too slow, need to upgrade firmware. Can't do it right now, but want instructions. Is there a pdf (or other) file that you can email to me for future reference? I want to make sure I don't screw up my current router settings--wouldn't know how to get them back. This really isn't my thing. Somehow when I was googling the other day I found instructions for doing this that included how to make sure settings were saved. I can find instructions on the linksys website but they aren't as specific as what I found at first.
To make matters worse, my printer just died. Bought a new one but not hooked up yet. I want to send the instructions to my office email address so I can print them there. Not my day.
The firmware will not speed up the router.
If you do upgrade firmware you will have to redo setting as they will be set back to factory after the upgrade.
If you need more speed first make sure its not your computer, or internet connection that is slow.
Think about getting a newer faster router....that one you have there is pretty outdated.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: INstallation instructions
By default the box will work (box is pre-configured).
For your ref. i am providing you the link with basic configuration steps.
http://www.columbia.edu/acis/networks/aptnet/linksys/index.html
SOURCE: i have a linksys wrt54g v8 cant connect to
Try this:
To configure your router manually:
Reset the router - Hold the reset button of the router for 30 seconds then Unplug it for 10 seconds then turn it back On.
Just follow these simple steps:
Open a browswer window and type http://192.168.1.1 into the address bar and click on Go.
The log-in window will appear.
Skip user name and type admin (admin is the default password) as the password, and click OK.
SOURCE: lost installation cd cant connect to wireless
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless
network then make sure that you are typing the
correct network key.
Click here for more information about routers and
network
SOURCE: How do i make my unsecured network secure?
Access the setup page of router by typing 192.168.1.1 in the address bar.
By default, leave the username blank and the password is admin.
Once on the setup page, go to Wireless. Under Basic Wireless settings, change the default SSID Linksys into any name. This will allow you to easily determine which is your wireless network.
Then go to Wireless Security and enable WEP. Type a passphase and click the generate button. Take note of the Network key. Remember that you will use this network key to all wireless computers.
On your wireless computer, view the available wireless networks or site survey. Select your SSID and enter the network key to connect.
I hope this helps!
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
