Question about MSI K8N Neo4-F Motherboard
My pc keeps shutting down. It's not a virus. I think it's either power supply or motherboard cmos battery. My MB is MS-7125. I want to replace battery. Where do I get it and what kind?
    President:
  • 2,030 Answers
Is it getting overheated?
have you cleaned the heatsinks and fans lately?
Heat id the major killer of computers....it could be you need to clean things up so it stays cooler.
Could be a bad power supply as well.
Posted on Nov 13, 2009
I need drivers fo pci for ms 7125 please send
Hello the download site is here:
http://www.msi.com/service/search/?kw=ms%20%207125&type=product
http://www.msi.com/product/mb/K8N-Neo4-F--PCB-1-0-.html#/?div=Driver&os=All
If the driver not fit select another MB.
First select your windows system.
The drivers you may download needs to be unziped
before you install.
Good luck
Jan 02, 2011 | MSI : 7125-040 (K8N NEO4-F) Socket...
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue
Mar 05, 2010 | Microsoft Windows XP Professional With...
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
Manual reset motherboard: Soyo SY-K7VME
Bios settings are retained by the Motherboard Battery in the CMOS. Disconnecting the battery clears CMOS and returns the settings to their original state. Typically this can be done by simply removing the CMOS battery and waiting about 15 seconds before reinserting and booting PC. Nowadays most Motherboard manufacturers supply a jumper to not only disconnect the battery but also ground the CMOS to effectively drain any residual power.
The instructions for your MB are found below. JP5 is located to the left of the battery and next to the PCI 2 slot on your MB. There is a Manual for your MB on this site and the MB layout can be found at
http://www.fixya.com/support/p281070-soyo_sy_k7vme_motherboard/manual-35533/page-5
Follow the steps below to clear the CMOS memory.
1. Clear the CMOS memory by momentarily shorting pin 2-3 on jumper JP5. Its white cap can easily identify this jumper.
2. Put the jumper back to 1-2 to allow writing of new data into the CMOS memory.
Jan 07, 2010 | Soyo SY-K7VME Motherboard
Biostar 945P-A7A motherboard: How do I replace the CMOS BATTERY?
I do know that the flat shiny side of the battery (+) is always up....and I've never known a mb to require 2 lithium batteries..
Apr 29, 2009 | Computers & Internet
I am working on a inel. The 5V light on the MB was blinking and of course, the PC wouldn't turn on. I replaced the P/S and the issue seemed solved - now the 5V light is on steady but the PC has an issue...
It sounds like your CMOS Battery is dead. As soon as you power down, your cmos loses it's information, however, keeping the battery in the motherboard completes the circuit and prevents it from restarting. Your best bet is to look what kind of battery your CMOS runs off of, this is common amongst almost all motherboards, albeit I can't remember which one it is off the top of my head. Anyway, Buy a new battery and replace old CMOS battery with new one. This should resolve your problem. If you still have problems after this, your motherboard might be damaged and you should look into getting it repaired or replaced. I hope this helps.
Mar 30, 2009 | Intel Motherboard
MS-7125 ver1 K8N Neo4 motherboard problem
Do you have the K8N-Neo4 motherboard? MS-7125 is the intern p/n for the K8N
If so, try this address, these are the most recent drivers for the motherboard.
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-7125&table=download
Hope this is the answer you're looking for
Nov 19, 2008 | MSI K8N Neo4-F Motherboard
CMOS problem! help!
Change M/board battery
if it keep going flat check all contacts are clean and not distorted
Oct 03, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
MSI K8N Neo4-F Motherboard Logo
217 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
