Question about Nokia 6680 Handheld
Memory Card Slot Problem
When i past the memory card into my phone slot it does not atomatically detect my data on my memory card
  • 1 more comment
  • boss707 Jan 08, 2008
    Sir u did not get my problem. Actullay my phone model is 6680 so the card slot is situated on right side on my mobile. So i don't need to restart my mobile while i past the card into the slot. It should atomatically detect my card data without turned off my mobile. On the other hand when i restart my mobile my mobile then data is appeared in memory card.
    Please give the better solution for this problem
    i am so much worry about this
  • gerrym210 Mar 18, 2008
    nokia 6680 cannot detect memory card
  • cheri3eLaura Nov 23, 2008
    my memory card slot also doesnt read the memory card... i need to push it just to read it! and that's not good.. i can't do that everytime...
  • 3 Answers
Well, this problem may appear due to your memory slot is dirty. Try this simple solution first:
  • Off your phone (IMPORTANT!)
  • Open your phone back case
  • Find the memory card slot
  • Clean the slot (gold stripes) with a rubber eraser
  • Clean the messy
Should work by now.
Posted on Jan 08, 2008
  • 100 Answers
Get a memory card reader adapter for PC, backup the card, then format it and get the data back on the card and plug into the phone and see if that works.
Posted on Jan 03, 2009
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning. repair memory slot
Feb 23, 2013 | Computers & Internet
How to remove memory card my n73
The memory card slot for Nokia N73 is located at the bottom of the keypad just above the charger connector.
  1. Before you eject the card, press the power key, and select Remove mem. card. All applications are closed.
  2. When Remove memory card and press 'OK' is displayed, open the door of the memory card slot.
  3. Press the memory card to release it from the slot.
Do not remove the memory card in the middle of an operation when the card is being accessed. Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
Jun 29, 2011 | Nokia N73 Cellular Phone
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
Its internal memory is 6 mb it is said that it suppots memory card upto 2 gb but it isnt detecting the card.should i activate it where and how
there's no activating stuff and all...
  • make sure that your memory card is working.(put it in your friends phone and check it)
  • then 2nd your memory card slot fine and working.
these are the only reasons which can be behind it.
  1. faulty memory card.
  2. faulty memory card slot.
have a great day!!
Jun 13, 2011 | Nokia 5200 Cellular Phone
How to remove the memory card from a c3 nokia phone
Hi kat_brynne
After reading the solution to your problem could you please rate if my answer was helpful thanks...
1 Open the cover of the memory card
2 Insert the card into the memory card
slot with the contact surface facing
up, and press until it locks into place.
3 Close the cover of the memory card
Remove the microSD card
Important: Do not remove the memory
card during an operation when the card is
being accessed. Doing so may damage the
memory card and the device, and corrupt
data stored on the card.
You can remove or replace the memory
card during phone operation without
switching the device off, but you need to
ensure that no application is currently
accessing the memory card.
Cheers nikki
Jan 22, 2011 | Nokia C3 Cell Phone
Memory card not detected
try to backup the data from the card and then format the card.and clean the phone slot for memory cards with some alchohol.but be carefull.
Feb 08, 2010 | Nokia Cell Phones
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Aug 04, 2009 | Canon PowerShot A720 IS Digital Camera
All of my files have gone :O
That means that the phone is not detecting the memory card.
this happens either when memory card is faulty, or when there is a problem on memory card slot contacts in phone (eg:dirt, broken contact).
Test the memory card on a computer with card reader.
If memory ccard does not work on PC, then the card is faulty, data may be lost. In that case test phone with new memory card.
If memory card is OK , try blowing into memory card slot in phone and reinsert memory card in phone after backing up your data.
If the phone does not work with more memory cards, then the phone memory card slot is defective.
Jul 11, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
PS2 8MB memory card not detected at all!
try put in another slot or blow or make shore all that silver stuff is on it
Nov 22, 2008 | Sony PlayStation 2 (PS2) Console
Memory Card not accessible
try to use oher memory card.... af same thing happens try to change memory card IC..... located near the memory card slot....
Sep 10, 2008 | Nokia 6681 Cellular Phone
Nokia 6680 Handheld Logo
164 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
