Question about Memorex MKS5009 Karaoke System w/CD/CD+G Player CD Player
The cd door is stuck - i cant open the door or close it, help? Same problem. I contacted Memorex and they said they no longer support this system and can provide no assistance. I removed the drive from the box but didn't see any obvious broken gears or belt, but I didn't really know what to look for. Is there any schematic online that would tell where the belt should be?           Thanks,                   Ed
    Scholar:
  • 152 Answers
I doubt that its possible to find a guide for that, since something with that much detail only goes in the patent and not in the manual.
your best chance is to see if there is a spring on the loose..but to check that you would need to open it and look for it...
i doubt the hassle will be worthfull....
Posted on Jan 08, 2008
6ya staff
SOURCE:
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Cd tray wont close, cds wont play
Sounds like you probably have a stretched belt on the load motor. Unplug the unit and remove the case which will expose the load motor. Plug in and turn on and press tray in button. You should hear the motor run and if you can see the belt you should see it slipping. Some belts are easy to change, and some are next to impossible. If you have to disassemble anything be sure that you note the position of everything as the timing of the tray, door, laser and most items in the unit is very critical. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 19, 2010 | Memorex Audio Players & Recorders
3-disk cd tray will open & then immediately close
I would suggest using Servisol Video 40 spray to clean any contacts inside the machine.
Mar 26, 2017 | Memorex MKS5001 Shelf System
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
The cd door is stuck - i cant open the door or close it, help? Tray does not open when switch is depressed. Green light burns steady.
http://video.about.com/pcsupport/Open-a-Stuck-Drive-on-Your-PC.htm
First, you'll need a paperclip. Unfold it so there is 1 to 2 inches that is straight.
Now, look closely at your drive door. There should be a very small pinhole either above or below it.
Insert the paperclip. There is a very small gear that when rotated, will manually open the drive door.
Retract and reinsert the paper clip as many times as it takes to eject the drive enough so you can hold onto it.
Pull Out the CD or DVD Drive.
Now slowly pull the drive out until it is fully retracted. Remove your stuck CD or DVD, and slowly push the drive bay back until the door is closed.
Apr 18, 2008 | TDK (DVD+RW47BXS5) Storage Media
How to get the drive to open?
I have a Memorex 52x CD burner. It bought it new and had no problems until about a year after I purchased it. Then suddenly, for no obvious reason, the drive would not open. The light flashed and I could hear the gears trying to open, but it would not consistently open. If I repeatedly pushed the button, eventually it would open.
What I finally discovered is that as long as I keep a disc in the drive, it will open and close with no problems. Now I keep a blank CD in the drive at all times, and so far the problem has stopped. I suggest keeping a blank CD in the drive so you don't lose a "real" CD forever (or have to destroy the burner to get it out). I don't know if this will work for everyone.
I DO NOT suggest inserting a credit card as another poster suggested. I tried this and it DOES NOT work. Plus you risk breaking the drive and destroying your credit card all at the same time (thereby delaying the purchase of a new one). Besides, credit card simply doesn't fit into the very small space around the tray door.
Based on other people's comments and the problems I've experienced, I'd suggest that people avoid buying Memorex products altogether. I bought this drive because my old one died and I was looking for a cheap burner to hold me over until I could afford to replace my computer. I may have saved a little money, but in the end I got what I paid for. My sympathies to anyone who's also experienced this problem.
Feb 13, 2008 | Memorex (32023244) CD-RW/DVD-ROM Combo...
C d door stuck
you can find a small hole at the front side of your cd drive , carefully insert any pin inside this hole and press it , your cd drive door will open.
Some time holding the cpu in 90 degree angle while system is on and pressing the eject button releases the cd door.
Feb 06, 2008 | Computers & Internet
Does not play CDs. After closing, tray immediately opens again and displays "Take CD out". Cycles through trays and gets stuck.
If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. If it wont help and you're NOT still under warranty you should at least open the system and look for Problems with the door opening/closing: Steps: 1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor. 2. Check for broken or loose gears and have them replaced. 3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players. 4. Use electronics-grade contact cleaner to clean the door-position contacts.
Jan 13, 2006 | Panasonic SC-AK600 CD Shelf System
Memorex MKS5009 Karaoke System w/CD/CD+G Player CD Player Logo
213 people viewed this question
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
headnsouth60
Level 1 Expert
Damen Wong
Damen Wong
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
