Question about Carrier 38BRC048 Air Conditioner
What is the blower model for the Carrier Unit FC4BNF042. My unit sounds like something is loose or flapping around the blower and up into the duct work. I believe it is the blower. I took the blower unit out and the wheel has a little play when move from side to side
    President:
  • 1,515 Answers
Hi, when you have a little play from side to side just shows very little bearing wear on the blower motor. In and Out play is normal. Spin the wheel to see if it is true. If the blower wheel has a lot of dirt build up on the blades it will cause it to be out of balance.If it is clean, but warped, take it to a motor repair shop along with the model and serial numbers. Call you're local wholesale a/c parts house with all of your info and they will look this up for you.The numbers that you have listed shows you have a 042 which is a 31/2 ton and 048 which is a 4 ton unit. More then likely, the wheel is out of balance and should be replaced, and they can look up the info you are requesting. Good Luck,
Shastalaker7
Posted on Nov 13, 2009
2013 Edge. Blower motor is fine,BUT NO heat...????
Hello, Sounds like the flap that controls the cold air and hot air duct is not working. One duct pulls air through the heater core where the other duct draw air from the outer vent. If that flap is not working, allowing you to pull from the heater core duct, then either the switch/lever that controls the flap is faulty (more likely) or the flap is stuck (less likely). Hope this helps.
Oct 21, 2014 | 2013 Ford Edge
How to connect a fan motor for a 7 ton carrier ac unit
7 ton, sounds like a commercial unit, if this so could be three faze. is this fan for cooling the outside condensor coils or the blower motor for moving air through the inside duct work
Feb 02, 2011 | Heating & Cooling
No AC
Turn off power, if this is a complete outdoor unit, remove the blower door Turn Unit back on see if the blower motor is working. If belt driven belt is loose or off, if direct drive and the fan is not working, its possible the capacitor is bad or fan is bad.
If fan is operating, then either a damper is closed, something is obstructing the duct or it is at to low
of speed.
Jul 02, 2010 | Goodman GPC1342H21A Air Conditioner
Rheem A/C unit makes a clicking sound when
Shut down the unit and turn the power off. Take the cover off of the blower housing and feel around within the squirrel cage. It sounds like something may have been drawn up into the blower. Also it is possible that the blower wheel might have thrown a balance weight and caused the wheel to become unbalanced. It could also be the motor about to go out but since I can't hear it myself, I'm trying to cover all the bases.
Mar 22, 2009 | Heating & Cooling
Carrier A/C Intermittent Shut-down Problem
It sounds like there is something in the system that is over heating. A t-stat will either work or it won't there are relays that have 24v coils and can become weak. If your air handler is shutting down it shut down the condenser, if the air handler is staying on but condenser is shuting down check the outside contactor. I am an a/c contractor and can be contacted at 504-722-3946 Eddie.
Sep 29, 2008 | Carrier 38BRC048 Air Conditioner
My blower motor doesn't blow air out the air ducts why
Friend,
Happy to assist you!
Perhaps a bad blower.
But sounds like low freon!
If freon is low unit will not go on!!!!!!
Could just be low or could be a leak!
Words alone will not remedy the situation!
Dop not wait to fix it next year!
The cost will be more then Bad Infaltion!!!!!!!!!
You need to call service !!!!!!!!!!!!!
Aug 29, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier, FC4BNF042
Chech for power to the ouside contactor and for 28 volts to the contactor!
Jun 29, 2008 | Carrier 38BRC048 Air Conditioner
Carrier 38BRC048 Air Conditioner Logo
277 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
