Question about Toshiba Satellite M35X-S114 Notebook
When I push the power, no display & button won't boot
When I push the power button it turns blue, the fan runs, no display and won't boot. can you help??
micromend
  • 748 Answers
SOURCE: Laptop won't start
You didn't mention the brand? First, take out the battery and plug in the AC adapter. Does it boot?
Leave the battery out of the computer a couple of hours, now put it back in and connect the AC adapter. Does it boot? If you still get nothing the computer needs to see a reputable repair person.
Posted on Apr 04, 2009
frankzjm
  • 191 Answers
SOURCE: Will not boot up
this is motherboard hardware issue
1) first all you need take out all devices like HDD DVD, wireless card then try turn it on if noting yet
2) change RAM stick that you have done
3) check DC PWM standby status, like 3V/5V/1.8V which should be appear before power on.
if no 3V/5V DC output, check this PWM circuite like MOSFET or PWM chip.
if you find 3V/5V, so need check 1.8V DC output and 1.2V that chip fail also cause nothing turn on.
all steps need diagram check where the chips and componenets on your board.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 27, 2009
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite A75-S209 (PSA70U-09700E) PC
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Posted on Nov 13, 2009
  • 2291 Answers
SOURCE: My laptop all of a sudden kept going into sleep
check ur charger, scan ur pc with reginout cleaner
Posted on Jan 13, 2011
SOURCE: I have a Toshiba Satelitte
I would suggest to remove Hard Drive and RAM. Then try to turn on. If it will beep and/or show any errors then you have faulty RAM and/or hard Drive. If it still blank, then most likely motherboard gone bad.
Posted on Aug 19, 2011
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
Systemax Ascent HA3200 RTS won't boot - fans come on - no display
The motherboard seems OK as it is displaying signs of life. The Monitor should display something before booting up, which it is not.Please do the following. 1. Remove the RAM and reinsert the DIMMs into their sockets and boot up. 2. Disconnect the HDD data cable from the HDD and the motherboard and reconnect. Boot up. 3. Disconnect the monitor and reconnect. Boot up. At boot up press F2 and set the PC to default settings. Boot up. Later when you want to apply your settings, keep noting down what you did when. Just in case.
Jul 17, 2010 | Systemax Computers & Internet
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the...
Good luck.
Nov 13, 2009 | Toshiba Satellite A75-S209 Notebook
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
Toshiba Satellite M35X-S114 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
