Question about Westinghouse 24 in. MDB421 RF Built-in Dishwasher
I have a Westinghouse Dishwasher. The water will not heat. what could be the problem
  • 725 Answers
It's very possible that your heating element has gone out on this unit.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we will be happy to get the correct element, along with part removal/installation instructions for you to repair this problem.
We answer our phones from 7 AM until 9 PM CST so call us when you are ready! Thanks, Ella
Posted on Nov 13, 2009
Testimonial: "Thank you for your prompt response. I have contacted Westinghouse part suppliers in my area and they are getting the part in for me. Thank you Ella "
Hi, my westinghouse wsf6605xr dishwasher is not drying dishes. Any ideas?
The heating element may be burned out, pull it out and test it for continuity of the coil.
Feb 23, 2017 | Westinghouse Dishwashers
Dishwasher not heating
I am guessing the hot water is not hooked up. Depending on the type of dishwasher and the setup of you kitchen, you can try to hook it up. You will need to pull it out to fix the heating.
Elisa Jed ' http://www.orlandoac.com/
Mar 24, 2014 | Westinghouse SB915
I have a Westinghouse SB915SJ*00 dishwasher. It runs right through a cycle but does not heat. Any suggestions? Thanks.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Sep 10, 2011 | Dishwashers
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
Does the dishwasher model GDB742RJS0 have a heating element or does it require a cold and hot water hook up thanks
Yes, your dishwasher has a heating element. You only need a hot water hook up. attached is a picture of some of the parts in your dishwasher. The heating element is #1. It is located at the bottom.
Hope this clear things up.
Please vote and add any comments you wish.
Mr Tin Man
Dec 21, 2010 | Westinghouse Microwave Ovens
No heatinh - Westinghouse SB925SJ*00 - suspect dual water sensor (Water presence and temperature). Require price and availability. Thanks.
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2010 | Westinghouse Dishwashers
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
No solution as yet, will most likely replace the dishwasher.
May 31, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
Dishwashers Logo
354 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
