Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
The router seems to disconnect me at random times - also lately I have noticed a fluctuation in speeds and strength of connectivity even though i am sitting in the same place.
  • 742 Answers
This could not be a router issue. Please call your Internet Service Provider regarding this and let us see that it can do from their end to correct this.
Posted on Nov 13, 2009
How can I troubleshoot My router? It is turning on and off all time.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Mar 16, 2013 | Computers & Internet
Internet connection lost every 30 minutes
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 22, 2012 | D-Link Xtreme N DIR-655 Wireless Router
I am connected wirelessly to an 802.11N Network. Why would my ps3 only get 1.1Mbps download time if it's reporting 95% signal strength? I can't even connect to the PS3 store the connection is so bad, i get...
Hi. Since you are getting a good signal in your pS2 connecting to your wireless router. Test your internet connection using this site www.speedtest.net. Your download speed should atleast 80% of the speed that you subscribed. For example, If you availed for a 5mbps connection you should be getting 4mbps or more when you test the connection.
Have a good one!
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
Hello, My roommate and I play World of Warcraft...
I would reset the router to default settings and use the good version of the firmware. OR delete your existing internet setup and then re-add it (do this if you didnt factory default your router before upgrading firmware)
May 20, 2010 | Computers & Internet
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Usb network adapter will not maintain connection even though I have good singal strength, 2 computers, 2 different adapters, same problem
Seems like you need to sync your modem and router. Disconnect the power to the modem and router. Then, first connect the modem and wait till all the lights are lit. then re-power your router. Restart your computers and you should be all set. Good luck
Aug 17, 2009 | Belkin (F5D7010) 802.11a, 802.11g/b...
Wireless Router Signal Strength
If is more signal strangth try replacing the atines with an upgrade antinas which you can buy from the routers website
Dec 17, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router
I use a second wireless card for just such issues.
the internal cards antenna is weak.
toshiba seem to be the worst about this to me.
Feb 03, 2008 | Buffalo Technology (WYR-G54) Router
D-link dwa-130 wirless
it happens to me also, always cutting off the signal, i just bought new one other brand and it works fine
Jan 27, 2008 | Computers & Internet
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
249 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
