Question about Acer 22" X223w LCD Monitor
Monitor displays no signal after I installed a new memory chip
  • 103 Answers
Your memory inserted is defective or not properly plug....try to disconnect it and connect again....also check your new memory if its compatible...
Posted on Nov 13, 2009
    Sergeant:
  • 194 Answers
Remove the memory that you installed...see to it if the memory has the same speed... thanks...
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Acer aspire m1640 repair
So the fan is running, what about the hard drive? Do you hear the hard drive spinning?
If it looks like it booted all the way except the display is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If you don't think the system booted all the way then try the steps below.
May 06, 2012 | Computers & Internet
Asrock motherboard chip problem how can display the monitor
Use a PCI-Express graphics card.
Explain the events as they happened in a Comment.
1) Turned the computer on one day, and no display on the monitor?
1a) Was No Signal, or something to that effect shown on the monitor?
2) Have you changed any hardware components lately? Ram Memory?
3) Has the motherboard been installed in a computer, and the problem/s happened,
OR,
Are you installing this motherboard for the first time?
4) Do you have a PCI-Express graphics card, and if so, what is the model name and number?
Regards,
joecoolvette
Sep 24, 2011 | Asrock G31M-S Motherboard
I install new memory 512mb pc133 sdram when I turn on my computer the monitor has power but will not come up display mode and the 3.5 floppy drive lite stays on constant with nothing in it and thecomputer...
You just answered your question. The memory chip must be bad or it is the incorrect chip. Try removing the chip and see if it boots up. If it does, teh chip is the problem
Jun 18, 2010 | EliteGroup K7AMA Motherboard
No signal and onboard video, bad memory?
yes normaly if there is a memory problem you will get no disply output hope this helps you can fix this by adding new memory and resetting the bios helps sometimes
Mar 18, 2010 | Computers & Internet
I put a new memory chip in my lartop and the
thus the chip you installed are compatible to your system? did you check the specification, try to remove what you installed and put back the old ones, see if it work
Nov 14, 2009 | Acer Aspire 3680 Laptop
Montior in Sleep mode
Take out the newly installed memory chip... If your sure its compatable with the motherboard, reseat it correctly into it's slot and fire up the computer. OR try rebooting with just the old memory installed. Monitor blackouts happen when the incorrect Memory is installed OR when the Memory is not seated properly.
stop chasing video and monitor problems...... :)
Regards..
Mar 27, 2009 | E-Machines eMachines Desktop PC
MY MONITOR DOES NOT COME ON
Doesn't turn on (power), or will not display anything?
Bad memory chips will cause the display to be inoperable.
I once put PC-2700 chips in a laptop that would only take PC-2100. The chips I received were wrong, but I didn't check before installng them. Anyway, it worked like a champ for about 5 mo. Then the display went out. I could tell that the computer was still operating, so I sent it back for warranty repair. Of course, the chips were aftermarket, so it wasn't covered under warranty, but that was the problem.
Nov 17, 2007 | HP Compaq Presario SR1300NX (PP195AA) PC...
Ghosting image after 3 years of perfect operation
ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Aug 11, 2017 | Hyundai ImageQuest Q995 19" CRT Monitor
Acer 22" X223w LCD Monitor Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
