Question about Bosch Nexxt 500 Plus WFMC5301UC
Bosch FL washer during spin sounds out of balance, but the machine is not jumping around.
  • 213 Answers
SOURCE: Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Posted on Nov 20, 2007
SOURCE: off balance during spin cycle
I have a Performa Model PAV3200AWW that would go unbalanced every time it would go into a spin cycle. I found the problem to be a worn out snubber. This is a plastic ring that is at the pivot point for the whole tub. It separates the metal to metal contact at the bottom of the washer pivot point. The part is less than ten dollars, but it is a quit a job to replace. I had to remove the whole tub to replace mine, but it did solve the problem. If you see a lot of plastic shavings around the pivot point, then this could be your problem.
Posted on Dec 15, 2007
SOURCE: New Bosch Front loader washer Maxx Classic WAE18060AU
if machine new have transit bolts been removed from rear of drum it amazes me how many of these get left in after delivery machine will go crazy if these left in drum should move backwards and forwards easily when door opened and drum pushes if solid remove bolts.
Posted on Jan 18, 2008
  • 223 Answers
SOURCE: Bosch nexxt washer is leaking from underneath
All the things that greendude said plus check the seams inside the drum as if these have even slightly parted it could cause the leak you're describing. Good luck.
Posted on Sep 26, 2008
huuum
  • 750 Answers
SOURCE: whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Posted on Oct 11, 2008
Why ?
do u have the wash load balanced , I noticed this in a lot of washer problems , people just throw the cloths in the washer without balancing the load , this is something that must be done on every washer and load , you must do this every time you use it , hope this helps ,
May 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
During spin, machine moves!
Did you remove the transport rods from the back of the unit? this will cause the unit to jump around a lot when it goes into the spin cycle. Also make sure the feet are all level and the unit doesn't rock from side to side.
Mar 22, 2010 | LG WD-16115FD Front Load Washer
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
NOISY DURING SPIN CYCLE
If this sound starts slow and gets faster till its helicopter sounding you probly have a verry worn spot on the drive belt when that spot goes around the pully it will thump the faster ti spins the more frequent the sound If you tilt the washer back you should be able to see the belt to examine it if this the problem
replace the belt
Hope this helps
please leave feedback
Nov 27, 2009 | Maytag Legacy Series Top Load Washer
Washing machine drum out of balance when spinning. have balanced machine and it does not vibrate or jump around. worse when on slow spin, real knocking sound
mine is also making noise during the spin cycle. Just paid $95AUD for the repairman to tell me it needs news bearings and that will be a further $300!
Oct 10, 2009 | Electrolux Washing Machines
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Remove the 4 transit bolts from the back of the washing machine. These are supposed to be remove during installation. If they are not removed the machine jumps around like crazy on the spin cycle and the machine is almost unusable.
Jan 12, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Bosch Nexxt 500 Plus WFMC5301UC Logo
219 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
