Question about HP G60-120US Laptop
How do I connect a projector to my G60 - HP G60-120US Laptop
  • 6,831 Answers
Hello
  1. Start by making sure the laptop and projector are both turned off before you start trying to make any connections.
  2. Locate the video cable -Usually your computer should have a svideo ort out. The projector should have either a hdmi or a RCA immput ports, thus you need a svieo to rca cable. Otherwise your laptop should have a VGA port oout where the projectorr should have a VGA port in.
  3. Make sure both ends are securely connected and tighten if necessary. Use a screwdriver or small pliers to tighten the connectors. A loose connection at either end will prevent you from displaying your presentation.
  4. Locate the audio cable and connect the audio cable included with the projector to the Audio Out on the laptop and Audio In on the projector. Make sure these connections are tight.
  5. Start your laptop and the projector. Make sure to check all connections to ensure they have been properly connected.
Really hope this can help you.
Kind regards
Andrea
Posted on Nov 13, 2009
  • 103 Answers
Use a vga cable to connect ur laptop to a projector...after connecting it setr your resolution to 1024 x 768 ..then still no output to projector use the function key the FN key then locate from f1 to f12 your dual monitor output....or right click then graphic option then output to monitor or dual clone monitor
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
I have a HP G60-435DX notebook that will connect to my DROID phone but it will not get an internet connection
GO INTO THE SECURITY SETTINGS ON BOTH ITEMS, THEN SET THEM 2 ALLOW EACH OTHER..
Aug 24, 2012 | HP G60-235DX Notebook
Connect g60 to sharp 42" hdtv via hdmi
They both will need to have hdmi ports so that you can run a hdmi to hdmi cable between them. If not, you will need some type of adapter that connects between them.
Once you have them connected turn the tv on and press Select Input from the Remote and Select HDMI as the input (If you have vga connections there might be a PC or Computer connection for it).
Reboot the laptop and the video should be on the tv.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 11, 2012 | HP G60-235DX Notebook
I have an hp g60 laptop I can't seem to get
Go down to the bottom right of your screen and click on your internet icon. See if it says connected or not....(looks like a staircase). Some wireless lights on laptops are orange....mine is.
Mar 13, 2012 | HP Computers & Internet
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
Feb 23, 2011 | HP G60-120US Laptop
How do I connect a HP G60 notebook to a tv with s video or rca connections?
this isnt the best way but its a nice one
http://www.amazon.com/TV-out-VGA-S-Video-Cable-Adapter/dp/B000P3UB24
Oct 03, 2010 | HP G60 Notebook
Replacing the keyboard on a hp g60 127nr
Take the battery off and there are 3 screws with a picture of a keyboard next to them. remove them and then lift up the keyboard from the top and carefully pull it out. Be careful because it is still connected to the laptop, remove the connection. there are 2 push clams one on the left and one on the right of the connection strip. after you remove that your ready to go.
Jul 09, 2010 | HP G60-127NR Notebook
My screen has spots of ink
Sounds like your screen needs replacement. If it is a laptop you may confirm this by connecting another monitor to the VGA output port (also known as the connector that you plug in a multimedia projector).
May 20, 2009 | HP Pavilion G60-120US NoteBook
HP Wireless "working" but it won't connect to networks
I had a similar problem with my HP g60-243cl and new drivers solved the problem. I also have to turn off wireless and turn it back on a couple times if I switch networks.
Apr 09, 2009 | HP Pavilion G60-120US NoteBook
HP G60-120US Laptop Logo
647 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
