Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
I have a XL12 UT 10445A and I need to find out the specs and also it is not gettting any spark
    President:
  • 2,220 Answers
  • 486 Answers
I do not have any specs on it, but parts are available.
The saw can have either points/condensor and/or electronic ignition
No-start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Posted on Nov 13, 2009
Homelite xl12 chainsaw
try a new spark plug
Dec 20, 2015 | Homelite Garden
Homelite com
Homelite XL12 parts manuals
Jul 27, 2013 | Remington Garden
Chrysler 3.3l has spark starts on starting fluid but wont start , replaced plugs, cam sensor, crank sensor, feul pump
Your fuel pressure release port is near the ignition coil packs on the fuel rail nearest cabin. Remove Schrader valve with core tool and affix a rubber hose and catch can. Turn key momentarily (Listen for pump) to "On" no starting. Turn key off and check can for fuel. If no pump hum was heard, check pump relay by swapping in another that's there in box ut, not equip. needed for eng. start like A/C. Test again. If you have fuel in the can, know you have spark,compression,and clean throttle path then, I would check/test fuel pressure.Chrysler spec. is 58psi +or- 5psi. If fuel pressure is there but below spec., my experience leads me to believe that the fuel filter above the tank is impacted and requires replacement, a line is kinked,or the jumper line within your new pump asssembly has a loose fit male to female connection and is bypassing fuel or sucking atmosphere at that union point.
Feb 07, 2013 | 2003 Chrysler Town & Country
I need a parts diagram of the homelite xl 12 with a ut number of 104564 serial number 790291696.
There seems to be 1 to many numbers in the model # UT104654 is it possible that it reads UT10465A.
If so here is a link to the parts diagram for a Homelite XL12 UT10465A ,
http://www.jackssmallengines.com/help.cfm#/Homelite/XL12_Chain_Saw_UT-10456-A/Engine_Internals/1010129/0609011010046
Aug 06, 2011 | Homelite Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
No spark superxl ut-10045-c
The following are givens:
1. You replaced the spark plug with a known good one and the malfunction persisted.
2. You did something similar to the following in an attempt to isolate defective parts and you concluded the ignition is not producing spark.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
I found your saw "SXLO Chain Saw UT-10045-C" by following the instructions here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
Both the solid state ignition and condenser (most likely failures, but no promises) are NLA at the authorized site, part numbers are still valid. An Internet search for "Homelite YourPartNumber" displays many sources other than eBay.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 03, 2010 | Homelite Garden
When started fisrt thing it runs on four cyilnders but as it warms up it getts better
sounds like it needs a really good tune up ,spark plugs ,leads ,fuel filter, and also the timing needs to be reajusted
Jul 05, 2008 | 1989 Honda Accord 4 Door
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
199 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
