Question about SanDisk Extreme III 2GB Secure Digital Memory Card
Why i can't go to my memory card,and its says file not formatted
    Sergeant:
  • 194 Answers
U must be format first to use in...
Posted on Nov 13, 2009
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
Samsung C322 is not reading the contents of the memory card. On clicking Menu> My Files, the contents of phone memory is displayed but the contents of the memory card is not displayed. Tried...
Your phone may be not supporting memory card format... or your memory card may be password protected... connect your memory with your PC and format it other file format. how to format memory card, do the following. 1 insert your memory card in card slot of your laptop or card reader or your PC 2. open my computer 3 right click on the memory drive or icon 4 click on format 5 change your file system 6 click start.
After formating insert your card in phone hope it will work for you.
Please do inform about dis, thank you
Apr 21, 2011 | Cell Phones
On pokemon XD it keeps saying that the save file currupts I have alot of room on it but it still crrupts so what do I do to fix this
  • Fully Corrupt:
    When the entire save area of the Memory Card becomes corrupt, the system will inform the player that the Memory Card is corrupt and offer to format it. The card must be formatted before gameplay begins or when the game attempts to access the Memory Card. The exact message may vary from software to software.
    Follow the steps for formatting a memory card.
    For specific issues with the Memory Card 1019, please click here.
  • Suggestion: It is always a good idea to copy your most important files to a second Memory Card as a back-up.
  • Data Area Only Corrupt:
    When only the data area of a Memory Card is corrupt (not the entire Memory Card) the game may not detect this until the Memory Card is accessed. Once it is accessed, the game will inform the player that the file being accessed is corrupt and must be erased. The game will only delete the one file being accessed and will not format the entire Memory Card (Other saved game files on the Memory Card may be OK).
    Follow the steps for deleting a file.
  • Memory Card is Damaged:
    If the Memory Card has been physically damaged, or has been damaged beyond repair, you will get this message. The Memory Card will need to be replaced. The system may attempt to format the card, but if it cannot it will give the error Memory Card is Damaged. There is no way to recover the game data from the memory card.
    Please use our convenient repair options.
This procedure is only used if a corrupted Memory Card is inserted into the Nintendo GameCube.
If required, this procedure will begin automatically when you select "Memory Card Screen" from the main menu. You cannot use this procedure to erase files from a useable Memory Card.
  1. After selecting "Memory Card Screen" from the Main Menu, if your Memory Card requires formatting, a window will appear to ask for confirmation for formatting.
  2. Use the Control Stick to select "YES" and press the A Button
  3. A window will appear to notify you that all data will be erased and ask again for confirmation for formatting.
  4. Use the Control Stick to select "YES" and press the A Button.
NOTE: When you format a Memory Card, all data will be permanently erased and unable to be recovered.
Jan 11, 2011 | Nintendo GameCube Console
I cant see any photos which are there in memory card in the gallery.
If you cannot see the pictures on your phone, that is on the memory then you need to format it with the steps below but before that connect the memory card to your pc an save all data there first. when finished with the format replace them back to the phone
NOTE: Format the memory card if you forget the memory card password. The device will allow you to format and erase the memory card password without asking for the password during the formatting process.
To format the memory card:
1. Press Menu
2. Select Applications
3. Select Office
4. Select File Mgr.
5. Select Memory Card and press Options
6. Scroll to and select Memory Card Options
7. Scroll to and select Format
8. Select Yes
NOTE: Format the memory card if it intermittently malfunctions (e.g. errors, file corruptions)
The Formatting option will properly configure the memory card for use with the phone.
Dec 05, 2010 | Nokia 5230 Cell Phone
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
Aug 07, 2010 | Computers & Internet
Will not format Memory Card for Use.
Hello my friend.
Try this tool which you can download clicking here.
It can solve your formatting problem.
- Download the file.
- Plug your memory card into your PC.
- Run the "exe" file that you downloaded.
- On the program menu select your device (memory card).
- Select FAT32 as file system.
- You may give a valid volume label.
- Uncheck the "Quick Format" option.
- Then start formatting your memory card clicking the start button.
This formatting will delete all the files in your memory card.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 28, 2010 | Kodak EasyShare Z740 Digital Camera
Memory card full
Using a memory card reader on a computer, erase unnecessary files or if the card is just corrupted, try formatting the card using the computer (use FAT16 file format in the format menu, not NTFS).
Mar 25, 2010 | PNY 2GB microSD Memory Card
When i click in memory card option,memory card not formatted shown,what will i do..........
select your memory card -> options -> format memory card option.
After the format you can use your card to store files as you wish.
Note: Format will erase all the existing files from your card
Thanks
Mar 06, 2010 | Nokia 3110 Cellular Phone
Corrupted mini sd memory card
sol..... Actually datastructure of ur memory card is damage. So format ur memory stick with ntfs file format(and do not perform quick format).
Aug 03, 2009 | SanDisk Memory Media
My memory card says it's not formatted but i have stored pictures, music and video's on my memory card. if i reformat my memory card, will i lose everything?
Yes u wil Loose ur Data, So before formatting, connect ur Memory Card to ur Computer via Card Reader and Take Back up of ur Media Files, then Right Click on your Memory Card Drive select FORMAT option and u wil get Format Window select Start, ur memory Card wil b Formated then u Can restore ur Media files to ur Memory Card.
Jul 14, 2009 | RIM BlackBerry Curve 8310 Smartphone
SanDisk Extreme III 2GB Secure Digital Memory Card Logo
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
