Question about Kitchen Ranges
Looking for Product Repair Manual
Hello, I have purchased the broken part (inner glass of oven door) for my KitchenAid range/stove model # ykerc506hw. However, before I go ahead and take apart the oven door, I would like to have the repair manual as a reference. Can you guys tell me where to get the repair manual free of charge specific to my brand and model! It would be much appeciated!!!
Thanks
  • Anonymous Jul 10, 2008
    GLASS DOOR REPLACEMENT
    Top Expert:
  • Kitchen Ranges Master
  • 52,940 Answers
Try Google
Posted on Aug 28, 2017
5 Suggested Answers
FreeTech
  • 426 Answers
SOURCE: broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Posted on Jun 13, 2008
reg501
  • 413 Answers
SOURCE: How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Posted on Jun 16, 2008
SOURCE: Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Posted on Nov 19, 2008
  • 254 Answers
SOURCE: Inner door glass replacement
open door fully, look down by hinges where enter unit, pull those metal tabs back that lock the door in place, close door to broil position 3/4 way closed and lift up, which should get the door off the unit.. once removed you would have to get acess inside that door by a combination on removing outer sccrews and hing screws and also seperating those glasses.....be careful to remeber how everything goes back i know of some techs that run into problems reassemblin those doors.. hope this helps,, some local service companies often charge a smaller in shop service call for small items like that if thats avaialable in your area,, hope this helps
Posted on Feb 07, 2010
Testimonial: "Thanks a million. Excellent!"
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
Broken inner glass door
NO,  I would not recommend this at all.  However, I have seen the stoves used without one of the inner glasses with no problems.   I am a factory servicer for frigidaire and have seen people use these with one of the glasses broken and haven't seen a problem yet. But again, it's not recommended. www.applianceoutletservice.com
Nov 01, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Broken inside glass door on my electric KitcherAid glass top range
sounds like you may have thermal breakage. does your oven have the self-clean option? you can have the glass replaced easily. i wouldn't use the self-clean option for now.
Aug 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
Broken inner glass on kitchaid range how to remove the door
Jun 12, 2008 | KitchenAid KGST307 Gas Kitchen Range
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
