Question about HP Pavilion dv9000z Notebook
I plug in my mouse to my laptop and it wont work, the bottem doesnt even turn red.. when i connect it all it says is usb device not recognized, it worked last night and tonight its not.
  • 788 Answers
Try disconnecting the mouse from the usb port and reboot the unit.
Now, on your touch pad, top left blue led is let showing it is functioning. Press the center button next to the led, which will shut off the internal mouse.
Plug in your mouse to a different USB port and the unit should see the mouse.
If not and the mouse does not light up, replace the mouse.
You may have had a conflict with the internal and external mouse.
Posted on Nov 13, 2009
Need to be able to connect to my computer . plugged it in but computer does not recognize the mouse . red light is on
My computer doesn't recognize my mouse and its not listed in ...
www.tomshardware.com > ... > Windows 2000/NT
Tom's Hardware Guide
Mar 25, 2012 - 9 posts - ‎7 authors
please help.....I am using my keyboard to move my mouse keys and it really sucks. After a storm everything came out fine on my diagnostic ... My computer doesn\'t recognize my mouse and its not ...
Feb 28, 2013
Mylaptop doesnt recognize the usb for my mouse ...
Jan 27, 2013
Computer won't recognize keyboard or mouse - Mice ...
Aug 27, 2012
Computer won't recognize keyboard or mouse? [Solved ...
Aug 6, 2011
More results from www.tomshardware.com
Mouse doesn't work in any USB port - Tom's Hardware
Jan 21, 2016 | Onn Optical Mouse
Dell 6420 laptop not recognizing USB ports while on docking station
Hello Jackie.
2 of youre USBs are USB 3. so you need to install the right drivers for USB 3.
Also you should check youre BIOS settings, if there is an option to enable "XHCI" support so enable it. (USB 3 needs this to work ).
regards Gue.
Apr 21, 2017 | Microsoft Computers & Internet
Help my mouse wont work on laptop
If your mouse works in another computer. Try to connect it into another USB laptop port. Goto control panel > Devices and see if your mouse is recognized and drivers are installed for it.
Give more details > Laptop brand model, Mouse brand model, Operating system.
Jul 17, 2011 | Toshiba Computers & Internet
My new GE 98812 ergonomic wireless mini mouse isn't working anymore. It was very simple to set up for the first time last night (right after I bought it), but today it won't connect at all, even though the...
on the bottom of the GE wireless mouse there is a connect button make sure to push it one time then on the usb there is a connect circle hold it as if you were going to pinch it sounds dumb but I was just having the same problem and I read one of the solution fixes and it said to push connect button on back of mouse and also push it on the usb where it says connect even though the one that you push on the usb stick isn't a button but it is sensed once held with pointer finger and thumb hope this better describes it to fix it
Sep 30, 2009 | GE Wireless Optical Mouse
USB device not recognized
Got the easiest solution to the problem. It worked for me, hope it helps all of you too.
First of all, if the device is unrecognizable, go to Device Manager and remove (not disable) the device. After doing so, remove the USB connector from the port.
Next, go to
http://www.logitech.com/en-my/support-downloads?wt.mc_id=usym_redirect_/index/downloads, and look for your mouse/keyboard etc model. Choose the one that you own and choose the Software Downloads option. Next, follow the steps and install the Logitech Connection Utility.
Once installed, follow the steps given and hopefully your device should be reconnected once again. Hope it helps all the best!
Sep 13, 2009 | Computers & Internet
My laptop mouse wont work
do you mean the mouse integrated in the laptop or an external USB mouse?
If it is the integrated mouse, try to get an USB mouse, plug it and wait until your laptop recognize it, assuming you are working in Windows XP right clic on My Computer, clic on Properties --> Hardware --> Device Manager , double clic on Mice and other pointing devices, once here, look for the mouse of your laptop (do not mis identify it with the external mouse that you just plugged) right clic on it and clic on uninstall.
Restart your laptop, once in windows again it will recognize the mouse as a new device and will install the drivers again.
Feb 24, 2009 | Acer Aspire 5920-6727 Notebook
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Computer wont recognize flash drive
unplug all other USB devices,(use the touchpad for your mouse) reboot and plug in the Sandisk. When another USB device is plugged into a stacked configuration, it's as if the second device is sitting behind the first and can't be seen in the crowd. I don't know if it's a USB mix and match problem or the stack or what, I just know that if the Sandisk is the only device in that USB stack, the machine will see it.
Jan 23, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
HP Pavilion dv9000z Notebook Logo
431 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
