Question about Dewalt 18 Volt Compact Drill Kit
Keyless chuck won't open, it has a screwdriver bit in it
  • 142 Answers
Try getting 2 pr of channel locks and grabbing each part of the chuck with them to try and get it to break open
Posted on Nov 13, 2009
Testimonial: "This worked. "
I attempted this and the clasp mechanism broke. With a bit still in the chuck you can not remove the set screw. This is a common problem that Dewalt denies warranty coverage for. Stop buying their product. They are not backing their warranty.
Posted on Dec 01, 2009
4 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
Keyless Single Sleeve Chuck
Your tool features a keyless chuck with one rotating sleeve for one-handed operation of the
chuck. To insert a drill bit or other accessory, follow these steps.
1. Lock the trigger in the OFF position as previously described.
2. Grasp the black sleeve of the chuck with one hand and use the other hand to secure the
tool. Rotate the sleeve counterclockwise far enough to accept the desired accessory.
3. Insert the accessory about 3/4" (19 mm) into the chuck and tighten securely by rotating the
chuck sleeve clockwise with one hand while holding the tool with the other. Your tool is
equipped with an automatic spindle lock mechanism. This allows you to open and close the
chuck with one hand.
Posted on Mar 05, 2008
  • 4102 Answers
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Hello, how do I change the drill bit
There are key and keyless drills and some have a quick connect spring device. To change the unplug then chuck open it all way & insert screwdriver. Most chuck screws are left handed (turn right to loosen) some drills have no screw inside the chuck. Insert a large allen wrench and tighten next hit the allen wrench counter clockwise to remove the drill chuck.
Jan 16, 2011 | Drills
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
Black decker drill keyless chuck won.t open !
hold the back of the chuck with channel locks or a vice and use the same channel locks on the front and open the chuck manually it should work and you can get to the screw to replace it or the hand chuck. this can be a little frustrating but hang in there and you'll be a pro shortly.
Sep 02, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Keyless chuck is locked in open position
First thing i would do is look inside the keyless chuck. Use a flashlight if necesary. If the 3 sliders in the chuck are the same ditance from the front then it is just stuck. If they are not then the chuck is jacked and needs to be replaced. If they line up the same then the chuck may have been on a bit of a bind, and then had some contamination in it. Usually rust will happen in here if it is humid where you live. The next thing to do is spray a bit of WD-40 or equivelant into the open chuck. Next thing to do is to put the drill in gear to go forward. Put a leather glove on your left hand to hold the keyless chuck. Set the clutch to maximum. Put the drill in the lowest gear it has and hold the chuck with the gloved hand. Pull the trigger as much as you can hold it as if you were sinching it down on a bit. If it don't break free then give it a sharp whack with a piece of wood from the side. (Don't beat the thing to death. One whack should do.) Try again. When you get it free'd up and you are storing your drill in the future it is always a good idea to leave the keyless chuck opened somewhere between all the way open, and all the way shut.
Presto.
Aug 20, 2009 | Drills
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Jan 28, 2009 | Drills
Keyless Chuck releases bit when reversed
hi
open the chuck all the way and then look down in the centre of the chuck you should see a cross head screw
unscrew and the chuck should pull out as this is on a taper system ( note the screw is left hand thread )
Nov 21, 2017 | Dewalt 18 Volt Compact Drill Kit
1 put in reverse
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
2,398 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
