My laptop l2000 screen is dim but i can see
My laptop l2000 screen is dim but i can see windows on the background if exposed to light i have tryed the briteness button but does not help
  • 460 Answers
The display backlight is burned out that is why its dark. it can be fixed but, the whole display has to be replaced..
Posted on Nov 13, 2009
My Sony Vaio VGN-NR498E laptop with Windows Vista recently had some issues. The light in the screen seems to have went out. If you hold a lamp up to the screen you can make out the background of the screen...
A dim laptop lcd screen is either the result of 1) a faulty inverter which is a separate piece from the lcd screen or 2) a burned out backlight which is part of the lcd screen. In the majority of instances, the inverter is the cause of the problem and not the backlight as most people tend to assume and therefore does not require the purchase of a lcd screen.
I have done some research and it seems you can fetch a new inverter for around $59.00
Nov 08, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Power is on but screen dont work
hi, try this get a flash light ,power on the computer, fase the flash light on the screen . see if you can the xp microsoft emblem in the background ill be dim .if so back light or invreter isout hope this heips
Sep 27, 2010 | ASUS Eee PC 1000H Laptop
I have a hp special edition L2000. Power is getting to the computer as the LED lights come on and then continuously blink. I can feel the cdrom running in a start and stop pattern, much like the blinking...
try to recover first your data, remove hard disk and make it slave to other station. copy all your files. then you may now reformat using a fresh install of windows xp.
Apr 13, 2010 | HP Special Edition L2000 LiveStrong Mobile...
I have a GemmaTech Durabook D15R Series. I was
You could have a defective screen, either a faulty inverter or a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Twinhead DURABOOK D14RY
Change boot sequence for HP L2000
You need to enter BIOS at startup. The correct key to press will be displayed at the bottom of the black screen when you bootup. Usually, F10, F8 or F11 or Del. Mash them all on booting up.
Now navigate the Bios settings with the arrow buttons and select cdrom as 1st boot device with the enter button. Then Save and Exit.
Fixya!
Chris (ziraffa)
Jan 10, 2009 | HP 418446-001 - HP Special Edition L2000...
Whenever i turn my acer on the screen doesnt show up and i know it is on, one time i started to be able to see the screen dimly but the contrast wouldnt turn up! please help
Try shining a flashlight or a lamp on the screen and see if you can faintly see the Windows desktop in the background. If you can then the problem is the backlight. Laptop screens have a light that shines from behind the screen and lets you see the display. If this is a laptop computer it will need to go in for service. If this is a monitor for a desktop computer you can try turning it on and off a few times, or leave it unplugged for a few hours and try it again but failing that it also needs service.
Aug 29, 2008 | Computers & Internet
Dim light on my sony vaio.
heres the solution! if ur fn + F5 key doesn't work...
1. go to start
2. go to control panel
3. click "power options" has a pic of a battery
4. click "change plan settings" under "balanced"
5. change "adjust display brightness"
May 23, 2008 | Computers & Internet
HP L2000 Screen DIM
Might be the brightness. Check if there are is a key combination for adjusting brightness.
Apr 17, 2008 | HP Pavilion dv6000z Notebook
IBM T22 Screen goes very dim and normal automatically
sounds like the LCD background light is either loose or going bad
Nov 10, 2007 | IBM ThinkPad T22 2647 Notebook
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
