Question about Garmin Nuvi 660 GPS Receiver
Touch screen won't respond on my Garmin Nuvi 660. Have tried reset but did not work.
  • Garmin Master
  • 2,130 Answers
The touchscreen needs replaced. Please see this link for more information.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Nov 13, 2009
4 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: nuvi 660 touch screen not responding...
Please see this link:
- Jim
Posted on May 24, 2010
sharcnet
  • 2130 Answers
SOURCE: i cannot do anything to it, wont respond to my
- Jim
Posted on Jul 01, 2010
  • 4 Answers
SOURCE: Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
Posted on Dec 02, 2011
Device: Garmin Nuvi 660 NA. After power on, nuvi boots thru to the "Where to" page. On the prior page, the touchscreen will not click "Enter" but after a time delay, nuvi proceeds to...
*Master reset your Garmin Device:
1.Start with the unit OFF and unplugged from power;
2.Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
3.Continue touching and holding the lower right hand corner of the screen then power the unit ON
4.Release the power button when the device powers ON
5.You will see a new message: Do you really want to erase all user data?
6.Remove your finger from the touchscreen when this message displays - Touch Yes
7.The device will automatically reset. Please follow the on screen prompts on the nuvi .
*If the touchscreen is incorrectly detecting where your finger touches the screen, the screen may need to be calibrated.
1.Power the unit On.From the Where to? and View map screen, touch Settings . Touch Display>Touch Re-calibrate
2.A new screen will display that says Press Dot,Touch the Center of the Dot.
>Keep touching the center of the dot as it moves around the screen.
3.When Calibration Complete appears on the screen, please touch OK.
The screen will now be Re-calibrated.
*If the screen is not responding to touch, the device may not have enough power to function properly. Recharge the battery completely and try again. If the battery does not charge, it may need to be replaced.
If the screen is still not responding to touch commands or displaying properly, the display may need to be replaced. If sound comes from the device, it is likely the motherboard is working, and only the display needs to be replaced.
Refer to:Garmin Nuvi 660 Screen Replacement Guide
Before replacing the display, check that the ribbon cables connecting the display to the motherboard are connected securely.
Oct 04, 2011 | Garmin Nuvi 660 GPS Receiver
My Garmin 660 Nuvi touch screen will not respond I have put in the latest update, held the start button down untill the touch dot calibration shows and tryed the reset button none of this has worked, no...
This is a common problem due to certain style of touchscreen that is known to fail due to temperature. if you can not recalibrate the screen, then the touchscreen needs to be replaced. More information, including the recalibration procedure can be found here:
- Jim
Jan 18, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 touch screen not responding
- Jim
May 20, 2010 | Garmin Nuvi 660 GPS Receiver
Touch screen locked and not responding. Nuvi 660
The touchscreen is intermittent and needs to be replaced. If your unit has a serial # that starts with "12P", "14V" or "143" then you have a style of screen that can fail without physical damage to the screen or glass. Please see this link:
- Jim
Apr 09, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 touch screen will not respond
on top of the device there is a lock slide switch, make sure its not on the lock symbol, other wise it will lock the screen touch feature.
Sep 27, 2009 | Garmin Nuvi 660 GPS Receiver
Not touch sensative
In 90% of the cases it's the digitizer (the touch sensor that is mounted in front of the screen). You can try to replace it yourself or send it to a third party gps repair service.
Jul 24, 2009 | Garmin Nuvi 660 GPS Receiver
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
847 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
