Question about Coffee Makers & Espresso Machines
How do you acces the power switch for replavement
How do you acces the power switch for replacement on the DX 30288 dishlex dishwasher?
  • 155 Answers
Turn of power undo control panel screws remove panel you should see the switch replace and re assemble hope this helps
Posted on Nov 13, 2009
Error 50 is coming up on my dishlex dx 301 and it is not working. It is about 3 years old.
A 50 Code means an electrical fault
This is something that is triggering the computer to think a conponant has failed
It could be a faulty motor for eg
Sometimes water in the door or condensation under the unit can cause this
Dishlex suggest you call their service center when this code comes up
hope this helps
Mar 27, 2015 | Dishwashers
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
Water wont heat on my dx 308 stailess dishlex. its ellectronic. is there a reset or does the heater ellement need replacing? cheers
Unplug your dishwasher,then remove the front upper control panel.You will see a series of plugs.Note where they all come from and carefully disconnect.On the circuit board you might find a track melted off.Solder a small wire across the 2 joints.See how that goes.
Dec 27, 2010 | Dishwashers
I would like to download a user manual for dishwasher dishlex global 300 DX 300 WA - thanks Lou
I think I have a PDF 300 Manual. Please email at mexeter@westnet.com.au and I will email it back.
Rergards
Mark
Sep 02, 2010 | Dishwashers
Wanting a maunal for Dishlex 300 global dishwasher. Model DX 300 WA * 01. Thanks
Try this site. www.appliancehelponline.com Just supply your model or product number.
Hope this helps.
Jun 07, 2010 | Electrolux Dishwashers
My dishlex dishwasher 160 series has stopped
Have you disconnected the drain, fresh water, power and the 2 to 3 mounting bolts to the counter?
Mar 07, 2010 | Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
Hello. Can i put an front panel on the door of my dishlex DX 103 to integrate it with the rest of my kitchen?
Yes but it must be a material that is made to withstand the heat dont cover any vents or spaces around the dishlex
Nov 09, 2008 | Dishwashers
Coffee Makers & Espresso Machines Logo
182 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
