Question about Mitsubishi WS-65909 65" Rear Projection Television
I have a mitsubishi ws-65909 - flashing 2,2. Can
I have a mitsubishi ws-65909. - flashing 2,2. Can you tell give instructions on how to fix it?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I have this information but it is too large to post here.
Let me know by rating this solution and I will find a way to give you the instructions.
SD TECH
Posted on Nov 13, 2009
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
How do I fix a convergence problem for Ws-65909
You have come to the right person:
all parts in this model for the convergence are located on middle board.
If set comes on and shuts off (green power light goes out) do the self check: press and hold (you may know or have done this) both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
That is short protect and a 98% chance one or both (usually one) of the two pico fuses that protect the convergence circuit have blown.
I will add some photos here one of the single IC this set uses for this, one of the protect resistors in front and to one side of it, and one showing the pico fuses (ones for the chip are circled)
A note= I have fixed a lot of these and have composed instructions which are based on doing it---tell you everything you will need and how to do the repair from start to finish--step by step.
I will not post them here as other experts will copy them and I spent some real time composing them.
If you want they are free--provide me a email address and I will forward them to you for free.
I have fixed almost a thousand of these sets (Mitsubishi) with this problem.
Copy and save the photos and let me know (you can post a comment here) if you have questions or want the instructions.
SD TECH
the photo for the fuses will not load---on middle board to left and towards the rear--green and location numbers 9fao4 and 05--both are marked 5 amp,.
Mar 23, 2012 | Mitsubishi WS-65909 65" Rear Projection...
We have a Mitsubishi diamond seriies ws 65909, we heard a pop noise (as if a speaker had blown but we still have sounds then the TV went to a rainbowish of colors and you view the picture as if it's 2...
This model uses a single convergence chip that after age fails.
I will attach some photos of the part, and also typical convergence problems.
The repair can be a do it yourself job if someone can solder etc.
The suspect part if it is a convergence problem is a SKT393-110(ABOUT A 15 DOLLAR PART ON EBAY).
If you are able I have start to finish step by step instructions for this repair that tell you everything you will need and how to do the repair.
Look at the photos and let me know.
sd tech
This is the part if it is a convergence problem.
No two sets will look exactly the same but the photos should tell you if it is a convergence trouble or not.
Steve
Sep 22, 2011 | Mitsubishi WS-65909 65" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Ws-65909 picture and sound are fuzzy, will a new power supply fix it???
It does not sound like a power supply problem. Most of the boards for this set are no longer available from Mitsubishi.
The most common problem these sets have is called convergence. Go into the customer menu with the Mitsubishi remote and select convergence--enter the "advanced" and look at the grid of lines (set will have on screen instructions for this) Let me know more exactly what your picture looks like.
If you need more help or advice rate this solution as I do this here for Free. Reply here and I will help you.
Regards, SD TECH
Nov 27, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Sep 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I am buying a Mitsubishi WS-65909 from aprivate seller and I read
You have been mislead. I just checked the service manual and that model does not seperate in two like some Mitsubishi's do.
Apr 18, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi ws-65909
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mistubishi ws-65909 will not come on
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Dec 01, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
287 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
