Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Trying to access the pump and motor section
I have kitchenaid dishwasher Kuds01flss2 and it will not start. It didn't drain and I want to see if something is in the pump. I'm not sure how to access the pump. I took the 3 screws out and that is far as I got.
Thanks,
Steve
  • 3 Answers
You should check the thermal fuse problem listed elsewhere on this site. My power went out on mine, and it was a cheap {less than $20 part} that snaps into the control panel. It eventually blew again a month later, and I replaced the heater element, and the new heater element came with a new board that was very easy to install. the new programming on the board actually speeds up the cycle due to a higher wattage heating element.
But what I didn't do the first time was replace the wires going to the thermal fuse that came with the replacement kit. (Apparently the OEM wires are too thin) Had I done that, I probably never would have tripped the fuse again and not bought the new heater element.
Posted on Feb 12, 2008
6ya staff
SOURCE:
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Apr 17, 2014 | Dishwashers
Upper dishes not clean on KUDS01FLSS2
Hi there, I had the same problem recently and instead of calling a repairman, I found these step by step instructions with photos on the web. Easy to follow and will save you $. http://en.wikibooks.org/wiki/How_To_Repair_Dishwashers/KitchenAid_Repair/Chopper_Replacement
Apr 20, 2013 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher fills but does not wash. Dishwasher will drain if program cancelled.
Do you hear a humming sound, like the motor trying to run, then stopping for a minute or two before trying again?
Usually, dishwashers run the motor one direction to wash, and the opposite direction to drain, but some use a valve to switch. If you see wires going to a bulky flapper looking part sticking off the side of the pump/motor, you might have a bad valve actuator.
Otherwise, you might have a motor refusing to turn in one direction. You can usually access the shaft from inside the tub by removing the washer arm to get access to the pump impeller. Do not remove the impeller unless necessary, but see if it will turn both directions. Broken glass or pieces of bones or other debris might be interfering with the rotation. If it turns freely both ways, but still won't wash, it is likely you have a bad starter coil on the motor, and will need to replace the motor/pump assembly. These usually have a longer warranty than the rest of the unit, so if yours is less than 5 years old or so, it would be worth checking with factory service.
May 18, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
My KitchenAid KUDM25SH has been operating fine for 9 years, but will not drain now.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 26, 2010 | KitchenAid 24 in. KUDM25SH Built-in...
My kitchenAid dishwasher won't drain well. the hoses are clear. solenoid seems to be opening and closing. What is my next step?
Hello there again I am really sorry we got disconnected
Please try this
The water doesn't drain from the machine
If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Jun 27, 2010 | KitchenAid Dishwashers
Kitchenaid dishwasher kuds24sewh2. It won't drain
  • A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
  • Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
  • Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
  • Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
May 04, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
373 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
