Question about Goodman GMS90703BXA Heater
My preasure switche is stuck open what can i do
    Sergeant:
    Champion:
  • 232 Answers
Often times you can just pull the vacuum tube off the switch and blow back thru it to clear. more stubborn clog may require removing tube from other end which would be on the induced draft motor and try to clear with a paperclip. then reinstall the tubing and retry
Posted on Nov 13, 2009
Honda 4000 motor runs great, pump not preasuring up water changed pump and no change, shaft from motor into pump was good felt like it was under compression but still no preasure
The pressure relief valve could be stuck open or faulty. The check valves may be stuck or plugged up. Try thoroughly clean these parts and see if that helps.
Bob
Mar 31, 2015 | Honda 13 Hp 4000psi 4gpm Pressure Washer...
My hoover washing machine will not stop fill with water it keeps overflowing can I do anything to fix it?
Does the water come in when the machine is off ? If so, the fill valve is jammed open and needs to be replaced. If the water only floods the machine when the machine is on, it is most likely the preasure tube is blocked or the preasure switch is faulty
Oct 04, 2014 | Washing Machines
Gould water pump water pump will not shut off ,have replaced preasure stwich &GAGUE,HOLDING GOOD PREASURE
Does the switch click open, if so it is wired wrong. If not it is set to high.
Aug 15, 2013 | Goulds Pumps Plumbing
I have a 2008 f-450 with 6.4 diesel my problem is on ocassion it will go into limp mode and the engine code is P0088 high fuel rail presurre do you know if that would be the High pressure fuel pump or...
This code is saying the fuel preasure is too high, this may be caused by a stuck fuel preasure control valve or a bad fuel rail preasure sensor, you would need to first check the valve to make sure its not stuck then test the preasure sensor, to test sensor a scan tool would be very helpful. hope this helps.
Sep 28, 2010 | 2008 Ford F 450 Super Duty
Where is the air conditioner sensor in ford fusion
There are a few sensors or as i call them switches, the low preasure/cycling sw. and the high preasure switch (sw.) theres a temp sensor inside the heater box on the evaporator core, the switches are located on the lines one is on the suction line and the other is on the high preasure line.
Jun 26, 2010 | 2006 Ford Fusion
Low oil pressure light is on on 2000 lexus rx300. Doesn't need oil or an oil change. Not leaking oil.
try replacing the oil preasure switch, if that doesnt solve your problem then have your oil preasure tested, if it really doesnt have oil preasure it will cause internal engine damage so start with the switch and then go from there, hope this is helpful.
Nov 29, 2009 | 2000 Lexus RX 300
Maytag washer will not fill
If it wont fill properly it sound to me me like a preasure switch. Take the control panel off and look at the load size selector switch (preasure switch). This has a hose connecting it to the wash tub. Follow that hose back to see if it may have some kind of blockage in the line. If not you may need to replace the switch.
Jan 26, 2009 | Maytag PAV2300 Top Load Washer
ADMIRAL LSD2615HEZ
Pls.check the unit if does have a low and high preasure switch,posible the system is in the low preasure that switch to cut off the unit.check system preasure,if low preasure found,you need to recharge the system.
Nov 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Goodman GMS90703BXA Heater Logo
105 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
