Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Two scews have fallen out from behind the back right knob. Now the knob will not turn. What's the best way to get the screws back in place to make the knob work?
  • 161 Answers
Unplug or disengage power to machine,remove knob by pulling steadily towards you,practice first on a functional knob or switch to gauge the "feel" of removal and reinstallation.. if possible screws can be reinstalled by grasping the shaft of switch w/needlenose pliers to help line up screw holes if working from front.if cant line up holes that way,remove rear panel to line up screws by grasping switch by hand from behind console panel.knob must be removed to reinstall the screws
Posted on Nov 13, 2009
How to change lower element
Turn off power remove two screw remove that hold the element in place place clothes pins on the wires behind the terminals so they do not pull back through the oven liner, remove the wires from the element and install on the new element. remove clothes pins and install the unit back into position and install screws.
Jan 10, 2016 | Ovens
Why wont the oven control knob turn
In a few instances like this, I found that the knob was forced on in the wrong place. Pull it off, and look at it, and slip it back on in the right place. Then try it again, let me know it this worked for you.
Mar 11, 2015 | Ovens
The glass panel behind the control knobs has shattered can I replace this model is stoves 720ef
The best bet is STOVES for a replacement - if they have one. It is relatively straightforward to replace. With all the buttons and knobs removed, there should be two screws underneath the panel , i.e. pointing upwards at either end of the panel,. The panel will also have two lugs along the top edge that locate into the top off the oven. The panels lugs should be first located into the oven before the screws are inserted. It may be a bit of a struggle but can be done.
Sep 11, 2011 | Stoves 720EF Electric Double Oven
How do I fit a new switch to the grill of my Soves electroc oven model no. 059040414 Type 720EF? Have you a manual?
First, a handbook is available, but I will need an email address to send it to you.
TURN THE POWER OFF.
To replace the switch, you have to take the whole oven out of its kitchen furniture housing and then take the top off. ) It is held in place by normal wood screwes) All the knobs on the front panel are pull off/push on and you have to remove them. Once you have the knobs off you have to remove the glass control knob panel. On the lower edge of it at either end you will see two cross head screws going upwards. Remove these. Now the only thing holding this in place are I think three lugs on the top of the glass panel that go up and in to the top of the cooker. With a bit of fiddling, the panel should now come off, leaving you free to access the switch for replacement.
I think you will find that the thermostat pipe will link into the top back of the top oven so this has to be very carefully replaced as well, which additionally may require the back of the oven to be unscrewed.
Best of luck!
Nov 06, 2010 | Stoves 720EF Electric Double Oven
Timer shows F30
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Nov 04, 2010 | Kenmore Ovens
How to connect a new element
The wiring has fallen back in behind the back wall. Go in throught the back of the machine and dont turn on the oven as you now have a live dangling back there.
Dec 09, 2009 | Ovens
Power went out is there a fuse
Hello there:
Depending on the oven and the age of the oven ther might be a set of fuses right behind the controle knobs on a controle board you need to remove the knobs and than from the inside there is a plate that needs to be removed and right behind this plate is the controle panel that houses the fuses and capacitors ok? I would contact the manufacture for additional assistance or you local appliance repairman.
hopt that this is very helpfull for you
Best regards michael
Nov 08, 2009 | Stoves Ovens
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
Element wires fell behind oven
I just had the same problem with our Electrolux wall oven. I don't expect you are still having problems 3 years later, but thought I would post for the benefit of anyone else with this issue.
Firstly, turn your power off. I then had to unscrew two screws on each side of the oven door which allowed the oven shell to come forward. You should then see the power cord which you can remove from the powerpoint. If your oven is hard-wired in, then I would definitely call an electrician.
Once I removed the oven, I placed it on the floor and unscrewed a few screws that held the top and back casing on. After removing the casing, you can see the wiring and you just need to push the fallen wire back through.
Before you put the casing back on, you could replace your element just in case the wire falls through again.
Sep 17, 2007 | Whirlpool Ovens
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
77 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
