Question about HP Officejet 6310 All-In-One InkJet Printer
Everytime we try to print something it keeps flashing reset the power. Also, there is purring sound that's coming frome somwhere near where the power cord connects to the copier.
    Problem Solver:
  • 5 Answers
Your printer is trying to talk to you, in its own limited way. If you are able to find the manual for the printer, it will list out all of the possible blinking light combinations, and a somewhat detailed summary of the problem. If you cannot find the manual, HP does have these available on their web sites. If you can either refer to the manual to see which blinking light combination is happening, or you can describe exactly the combination of lights, and the frequency (fast or slow, steady of intermittent, I can assist you better with determining the cause.
Posted on Nov 13, 2009
How does the pur water filter work? Is it powered by a battery or is something else involved? My light will not light green or red after changing the filter sometime ago. Does it come apart?
it runs by water preasure. filter does not come a part. try to unplug the fridge for few minutes and plug back in. if that does not help see instruction to reset yje unit
Jan 20, 2015 | Refrigerators
Lights flashing 7 times
Never heard of 7 flasjhes.
Five flashes = No Print Head Installed. Install or re-install.
Eight flashes = Waste ink absorber* almost full. The printer has a built-in waste ink absorber to hold the ink consumed during Print
Head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the R R ESUME/CANCEL button to clear the error so printing can continue for a while.
A longer term RESET IS possible BUT without changing the blotters, you're exposed to ink eventually running out of the printer without warning but... if you still want to continue, here are the reset instructions. Good luck!
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green.
Now press the resume button 4 times and then the power button. You've just reset the waste ink counter. Good luck. Just hope it doesn't come back to bite you!
Aug 31, 2014 | Canon PIXMA iP2000 Photo Printer
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Not printing, flashing amber-green light. Message says waste tanks are full....................HELP
Hi there! Follow those steps: i250, i350 and i000 series
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
This method will work only whilst the printer's connected to power. Turning off and on at the switch will keep it, but unplugging it from the power will reset it, which means you'll have to do this again: What this does is temporarily reset the printer, but also stops it from doing headcleans everytime you open the door to switch print heads or ink tanks.
Thaky for using Fixya.com
Nov 24, 2010 | Canon i350 InkJet Printer
Blue power light keeps flashing, but the tv won't turn on
Same thing just happened to mine. I think these replacement lamps (L2114A) are nearly impossible to find. They are no longer available through HP and I've ben unable to locate one through a reseller.
Oct 31, 2009 | HP Md5880n 58 in. HDTV
Paper catching
the paper sensor could be bad, try manually selecting the paper type, plain paper etc...
Mar 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lanier 5645 cannot reset printer red button just keeps coming on
when you press the 'red' button, it probably says 'paper mismatch, or load "XXX" paper, and you can override it by selecting one of your paper trays manually? It is likely a "legal size document' and you don't have legal size paper loaded, or something along those lines. Try printing the document after manually selecting the paper size/tray (turning off auto paper select) in your printer preferences dialog box on your PC first.
Mar 02, 2009 | Lanier Office Equipment & Supplies
Canon Pixma iP1200 always reports "Paper is jammed"
You need to reset the printer!
for more details about software for your printer click HERE
Oct 19, 2007 | Compaq Armada M700 Notebook
HP Officejet 6310 All-In-One InkJet Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
