Question about Freezers
Rough idle. ck engine light on.replaced plugs and wires 20 months ago.(Runs fine at hwy speed.)
  • 11,896 Answers
I would say either vacuum leak or bad 02 sensors. Usually when check engine light is on, there is bad sensor or circuit. Bad idle and check engine is likely bad 02 sensors and running rich/lean
Posted on Nov 13, 2009
Hotpoint fzfm151p. Bought a year ago. Worked fine up until I moved this month. My dad placed freezer in garage by mistake. Lights flashed (all) ever since it was in there. I've just moved it into the house...
Freezers have an electric motor within to pump the freezer gas around. Its possible the movement has caused a problem. Get ban appliance shop or tech to check it out.
Dec 29, 2014 | Freezers
We moved a week ago and just now plugged in the freezer and no power at all.It worked just fine before we moved
it is possible the freezer went into a defrost cycle leave it plugged in and in about 20 minutes it may come back on, or you may have a dead plugin . plug something else into the plug to make it is working
Jul 19, 2014 | Danby Freezers
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Frigidaire 20 cu ft. upright freezer went out a few days ago. Discovered bottom seal was not in place but fixed that. Alarm light stayed on through the night and freezer is not cooling AT ALL although...
Is your compressor kicking on? If not then check the contactor-relay and the capacitor. If that isn't the problem then it is probably your compressor. Which is quite expensive to replace.
Aug 08, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
FREEZER IS NOT FREEZING IT IS 18 MONTHS OLD. WE DEFROSTED IT AND IT FROZE AN ICE CUBE TRAY SO WE MOVED IT DOWN STAIRS PLUGGED IT N AND IT NOT FREEZING AGAIN????
It is possible to cause an air lock when moving an appliance by tilting it and then not allowing the refrigerent to settle before switching on. Try unplugging it and laying it on its side for a couple of minutes, then put it upright and leave it for 6 hours to settle, then plug it in again.
Nov 28, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
Manitowoc SD 0852A ice maker compressor will not kick-in
Here's my thoughts, I hope it helps. I'm going on foggy memory here, so I may not be entirely correct.
I worked on something like this a few years ago. The icemold (plate) is vertical, there is a circulating pump that runs water over the mold, with the water freezing as it passes. The sealed system is a heat-pump scheme, it freezes the mold to form the cubes, and reverses to heat for release. And when it works, it makes ice fast. It runs constantly until the ice hopper is detected to be full. (there should be a bail to detect the ice level) The system will not run in the event that it thinks the hopper is full (bail up) but the pump motor runs continuous to avoid it freezing. There is probably either a false detection of "full" or there may be a leak in the sealed system and the system will therefore not run.
Jun 28, 2009 | Freezers
Defrost circut wired hot nuetral ,should this be d/c with a transformer
Probably uses a Paragon 8145 timer. Wiring as follows
L1 to 1/2 on timer, L2 to 2 on timer, Defrost Heater to 3 on timer,
Compressor to 4 on timer, Klixon to X on timer
May 22, 2009 | Hussmann Commercial Freezer DCCG-8
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
