Question about Health & Beauty
My braun contour 5000 series razor leaks more than half of a brand new cleaning fluid container when I do a routine cleaning. Obviously this isn't exactly a "dishwashing" category, but there's no better category to select. What's going on?
Its no good
Posted on Dec 13, 2009
    Problem Solver:
  • 17 Answers
The seal o ring is leaking
Posted on Nov 14, 2009
How to fix a Braun series 7 razor that will not charge in cleaning stand
Try plugging the cord directly into the shaver. If it charges this way, your clean and charge unit is bad. A replacement can be ordered from the link below
http://shaveroutlet.com/braun-pulsonic-clean-charge-base.html
May 27, 2014 | Braun 7000 Series Foil and Cutterblock
Braun series 7 cleaning station has red lights even after I replaced the cleaning solution
When the razor is not regularly cleaned in the cleaning station and the hygiene indicator goes low, the cleaning station may lose its ability to sense the fluid level. I almost sent the cleaning station in for repair (mine is out of warranty) but was able to clear the faulty condition by resetting the razor's cutter replacement (holding the small recessed reset button below "Braun" logo on the razor) and unplugging/replugging the station then attempting a cleaning until it performed one completely successful cleaning cycle. After that the fluid level showed full. I also heard that the drain hole in the "cup" where the razor sits can get clogged - not sure what happens then but you want to keep that clean.
Sep 15, 2013 | Braun 8585 Electric Shaver
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
My base does not pump cleaning solution thru the device. I will run the entire process, & there will be clippings in the bottom of the slot where the razor sits. The solution container is full, but...
The pump in the cleaning maching is broken. Pumps are not available seperately. Your only option is to purchase a new cleaning /charging machine. You will find this item for model 7570 available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Mar 06, 2011 | Braun Syncro 7570 Electric Shaver
My cleaning container will not go to green after I insert a new cartridge. Never had this problem before. This is my fifth Braun shaver. I have a pulsonic. It is about thirteen months old. Shaver works...
Are you using the cleaning solution? On the following web blog, it talks about the razor, and mentions the cleaning solution, that is needed:
http://www.shavingstuff.com/archives/014524.php
I saw similar problems reported on the net, and they had to send the unit in for repair and replacement of some "parts".
You might contact Braun, and see what support they can offer you. Here's their site:
http://www.braun.com/
Good luck, and hope this helps.
Dec 28, 2010 | Braun Pulsonic Rechargeable Cordless Men's...
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Non cleaning razor
Dear Freddofrog,
please ensure you have removed the plastic plugs from the cleaning fluid container. If you have removed these i would suggest that the fluid contaner is faulty, your place of purchase should exchange this for you with no problem.
May 27, 2008 | Braun Flex XP II 5790 Electric Shaver
Health & Beauty Logo
207 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
