Question about Pioneer GEX-P920XM Satellite Radio Receiver
Fuse keeps blowing when i hook up ground - Pioneer GEX-P920XM Satellite Radio Receiver
2001 Cadillac Deville hooked up jumper cables wrong to battery. Some fuses blown have changed all but one, the one says elec under the back seat will not take a fuse they just keep blowing out. Fix??
You have a short to ground ! one says elec under the back seat will not take a fuse they just keep blowing out. Fix?? Could you explain this a little better ? Videos on youtube find a short !
Apr 24, 2017 | Cadillac DeVille Cars & Trucks
My park lights keep blowing fuses
You have a short to ground in the park light circuit..best have a mechanic look at it because its possible the trailer wiring was faulty and shorted out the Smart Junction Box (SJB)...the park lamp relay is controlled by it and the relay is built into the SJB
Apr 13, 2015 | 2007 Ford Ranger FX4 Off-Road
Why is the ignition fuse keeps blowing and blowing main fuse
It's called a direct short to ground. Whatever is on those fuses needs to be checked. Main fuse, is it blowing when you turn on key or when you hook battery? If with switch then trace hot wires from switch. Blown fuses are from overheating, which is what a short does.
Oct 11, 2014 | Motorcycles
Keep breaking fuses on T/L Ctsy after my son hooked a power wire there for his amp. now it keeps breaking fuses.whut can i do to fix this.
it sounds like the power wire you Son hooked up is not grounded and keeps blowing fuses. Try grounding that wire and make sure its not touching any others to spark and burn out fuses.
Oct 14, 2011 | 1991 Chevrolet Suburban
I have a 1997 chevy silverado and I keep having a fuse blow that makes my hazzard lights and brake lights not work plz help me
If you have a trailer hook up, check that the wiring is not touching ground. Constant fuse blowing is an indication of a short to ground.
Jul 18, 2009 | 1999 Chevrolet Silverado 1500
Difficulty wiring into GM harness
well if your trying to actively wire it up with the car battery still connected that is why you are blowing fuses. just a heads up too if you have a live connection while hooking up the cd player you could short out other electrical devices and you could be in alot more trouble thatn just blowing fuses. the black wire is what is blowing fuses its because you have it hooked up wrong to a wire that is sending voltage not recieving voltage. ground the black wire to the actual chassis instead of hooking it to the ground wire from the harness or whatever color its grounded to which shouldnt be anything but black if you have the black wire hooked up to ANYTHING that isnt black that is why you are popping fuses. so hook up the red yellow and make your own ground you shouldnt have any problems after that.
May 08, 2009 | Car Audio & Video
Tail light fuse keeps blowing
where do you have the power wire for stereo hooked or hooked into?
Jan 18, 2009 | 2001 Lexus IS 300
Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Jun 12, 2008 | Kenwood KAC-728S Car Audio Amplifier
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
Pioneer GEX-P920XM Satellite Radio Receiver Logo
75 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
