Question about Kettler Mondeo Elliptical Trainer
Electronics are not working when I plug it in nothing happens not even a beep
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Does the outlet work? Possible it has an in-line fuse or circuit breaker ,if circuit breaker it would be a button or it could be on the motor but if it kicked out it happened for a reason usually over heating or over duty of the unit. In any case take it to some one who knows whatr they are doing and save yourself the head ache.
Posted on Jan 10, 2010
My frigidaire side by side model#GLHS37EHSB7 is making a constant beeping noise and the electronic temperature display isnt coming on. what could be causing this
Hi Julie, this is JK. Thank you for your recent post!
I see that your Frigidaire Refrigerator, GLHS37EHSB7, is constantly beeping but the electronic temperature display is not working. Generally, this could happen when you experience a power failure. I would strongly suggest that you either unplug or turn the circuit breaker off to the unit for about 30 minutes. Let the unit reset completely and try to use it as normal again. If this concern still continues, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Hope this helps!
Mar 19, 2014 | Frigidaire Refrigerators
My Brother NX200 has stopped working it does not beep when I switch it on
could be the on/off switch has gone out, could be the motor, or a part is broken, if it's electronic, the computer could have gone out
it would have to be checked to see what happened
Mar 18, 2014 | Brother XR-65t Mechanical Sewing Machine
I have a Kenmore model#9114552192 serial #3v400949r It is making a beeping noise and flashing "F-1". It still seams to work but the beeping will not quit.Do you have any suggestions?
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Kenmore Kitchen Ranges
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
The beeps start slowly then get faster and faster - it beeps for over a minute then stops. 5 mins later it does it again, then again. then nothing more until say the next day. The console is is standby...
i think there mite be som problem with settings...did u use any unauthorised cds or internet program...or u mite used it for a long time..u try this site to solve your problems click hear
Nov 04, 2010 | Sony Playstation 3 (PS3) Console
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a mah5500b. prob is washer will not start or do anything. it just beeps. tried the diagnostic test. by pressing delicates and heavy soil. led shows 00. when i push other buttons to check functions....
I had a similar problem on my Neptune. All the machine would do is beep. I believed it was a stuck button so I got a new touch pad and that solved the problem. I also substituted a control board prior to buying the touch pad but the problem was the same.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sharp Carousel Convection ModelRK93S3. Plugged in, not operating
1 of 2 issues is the main 20 amp fuse the other issue could be the thermal fuse..
Dec 25, 2008 | Microwave Ovens
Kettler Mondeo Elliptical Trainer Logo
387 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
