Question about Air Tools & Compressors
I replaced a burnt out light bulb with another and it blew out very strongly. The door now does not close and any bulb I try will not go on. There is power to the unit and I hear a clicking sound when I try to close the door or turn on the light. Thanks
  • 5 more comments
  • pjjmartin Nov 13, 2009
    This is a problem I am having with my craftsman 1/2 hp garage door opener. I do not know what expert to select from the list.
    It has two household light bulbs, it has a remote and a wall control, and it has a learn button on the motor unit that flashes when i try to use it
    I have a craftsman 1/2 horsepower garage door opener. It was working fine until I replaced a burnt out light bulb with another one. Shortly afterward the bulb blew violently. Now the door does not open and the replaced bulbs do not light. There is power to the unit and it only clicks when i try to use it.
    In the pick an expert list who am I supposed to pick?
    I looked everywhere on the surface of the motor unit - could not see a reset button. Do I have to open up the casing?
  • pjjmartin Nov 14, 2009
    The sensors are orange and green so that is not the problem. When the light blew would that fry something? I took off the covers and I did not see any reset button or any sign of melting.
    I need to know what you mean by testing a relay of door latch. Where are these contacts? More detail needed.
    Hi Stephan,
    I could not find any plastic enclosed relay. I called Sears and technician said I needed to buy a $160 logic board! I have pulled out the logic board for inspection. Any final ideas or knowledge about logic boards?
    peter
    President:
  • 1,015 Answers
The fact that the light bulb blew very strongly leads me to believe that there is an electrical short with the opener and it is very possible that the logic board was damaged from the short. You will need to start by inspecting the wiring that goes to the light bulb socket. See if the wiring has melted and is shorting to ground. Is the light bulb socket housing loose? You can use a fluke meter to test the light bulb socket for correct voltage. Also check both legs of the wiring to the light bulb socket. You will need to find the short before replacing the logic board or you could damage the new one you install. the clicking sound you hear is for the relay that turns the light on and off when the opener is not operating properly. Let me know if you have other questions.
Posted on Nov 14, 2009
    Guru:
  • 194 Answers
Hello pjjmartin. I have some experiance with garage door openers but not as much craftsman openers. It sounds like you blew the relay. Was the bulb you replaced the original bulb with rated higher than the original bulb? The relay works as follows. When you push the open button on the remote , a low voltage circuit usually 12 V (called the control circuit) closes and this creates a magnetic pull in a magnetic inductor. This pull closes the main circuit and allows the lights and motor to operate. The reason this is used is because the motors sometimes have a very high starting current which could not be handled directly by the components in the circuit board. If you open the plastic cover off you opener , there should be a circuit diagram on the inside of the cover showing you the position of the relay. It should look similar to this on the diagram : What normally happens is that the little plate in the relay that connects the main circuit burns into place as it makes contact. This will probably also blow your fuse , so replace the fuse too. The relays don't all look alike , but you should not have trouble spotting it as it is a big component normally with a clear plastic side. Replacing this relay should solve your problem. (Also remove and reinstall to test the connection before replacing). Most of the time you can simply pull the relay from it's holder and replace it. They cost about $10 - $20 dollars and be sure to replace it with the same rated relay. You can buy this at most big electronics and hardware stores. Sometimes it will be soldered into the circuit board and in this case you will need to unsolder it first. SAFETY WARNING : Always remove the plug from the unit before doing any work on it. If you need more information , please do not hesitate to contact me. Kind Regards Stephan
  • 4 more comments
  • Stephan Reichert
    Stephan Reichert Nov 14, 2009
    Sorry for the squashed post , I do not know why it did that and will follow up with the technical support staff.
    Was
    If you open
    replacing).
    work on it.
    contact me.
  • Stephan Reichert
    Diagram of Control Circuit and Main Circuit
  • Stephan Reichert
    Electrical Symbol for a Relay as seen on the wiring diagram
  • Stephan Reichert
    Picture of what common relay's look like
  • Stephan Reichert
    Stephan Reichert Nov 16, 2009
    The problem you have is that they probably work with a integrated relay on the board which is why they are asking you to replace the whole thing.
    It's basically a gimmick to help the company who makes these make a profit out of you each time you have a hickup with the unit. It is unfortunate but ultimately unavoidable.
    Good luck.
  • Stephan Reichert
    Peter
    Just a final thought before blowing a small African town's income for a month. (really ridiculous cost!)
    Check all the capacitors (blown will probably be leaking) and check for burns or bad solder connections on the board.
    Smell through the board or get someone with a good sense of smell to do it....as you know...burnt components smell really bad and it should make it easier to spot a problem if you have a clue where to look.
    If you have a manual voltmeter , test the transformer (if there is one) with a battery. (will not work with a digital voltmeter)
    Double check your plug and measure to see if you are getting power just before the unit.
    That's about all I can think of right now. Will add if I think of anything else to do.
    Regards
    Stephan
  • 788 Answers
Ok, on your garage door.
The noise you hear is normal when the door sensor's are not seeing each other.
At the bottom of the garage door, on both sides, you should see 2 sensors. These are motion activated. Another words, if something go across the sensor while the door is closing, it will stop the door as a safety. Or in some doors, if the door is open and you walk by the sensor, the garage light will turn on.
If one on these sensor's are out of alignment, the door will not close and the clicking noise is the light relay, which is supposed to be blinking.
Look at the senor on either side and you should see a orange light on one side and a green light on the other side.
If the sensor's have been kicked or moved out of alignment, you will have to line them up until you have the above configuration.
You should not have to reset or remove any covers. Do not push the orange or green learn button, as that is not your problem and will not help the currant situation.
Also, you should only choose the most helpful technician as only one can receive credit for you problem.
Thanks, let me know if you need more information.
Posted on Nov 13, 2009
  • 11,896 Answers
Either the door latch or a relay is bad. You can use an ohmmeter to test both.
  • 6,927 Answers
Sounds like the door latch switch is busted,and is shorting,I am guessing this is a oven?it says air compressor at the top,really don`t know what you have.
  • 4 more comments
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 13, 2009
    Might be the control board,I don`t know with out inspecting it,brands do not help,does it have a house hold bulb?and does it have remote?or on the wall control?If it is the on the wall control,take the control apart,and look for a short in the circuit board,and in the wiring.
  • Ronny Bennett Sr.
    Also look in the motor control and smell the motor to see if it has a burned smell,and look for shorts there.
  • Ronny Bennett Sr.
    O k,look where the motor is,and look at the motor control for a reset ,most likely a red button,to reset.
  • Ronny Bennett Sr.
    Yes,the casing,not the motor casing,but where the motor and gears are at.
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 14, 2009
    The door lift at my work has a 110 house hold bulb in it,if the bulb burns out,it will not work,like a fuse,I suppose,I have seen this in guitar amps and such,look in the socket,with the system unpowered,and check to see why it blew,maybe try to replace the socket for the bulb,this may be a inline circuit and will not operate with out the bulb,let me know what you come up with.
  • Ronny Bennett Sr.
    Forget about the door latch thing,they have you under compressor,and I had another one under the wrong one,and got his messed up,and yours,but what I said about the light bulb,do that,and let me know,please,I am wondering on this one,and I think I am on to something.
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
I have a 2 year old Kenmore HE3 electric Dryer. Model 110.8708. The drum light never worked. I opened up the door and found a broken bulb. I replaced the bulb. the light stays on all the time,...
the door switch has something wrong with it,it's keeping the bulb on all the time and that's why it burnt out the first time,also you're missing the last four numbers on the model number
May 15, 2011 | Dryers
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
How to get to stop light in back window of 95 lincoln cont. Bulb is burnt out. do we change from trunk side or inside of car? also have a problem with interior lights staying on for a long time after car...
First, the stop light bulb is accessible from inside the car. The cover can be removed by pressing down on the center of the unit and pull back toward the front of the car. Once off, you will have access to the bulb itself
You have a sticky door switch. Apart from replacement, best course of action is to spray the switch (all throughout the inside of the door/lock) with WD-40. Since you're unsure which switch is sticking, repeat this procedure on all doors. Once thoroughly lubricated, open and close the doors several times. This should fix your sticky switch problem.. Best of luck.
Greg
Jun 08, 2009 | 1995 Lincoln Town Car
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Flash and Bang on Closing Door
Since you know that the bulb is blown that needs replaced. I would go ahead and replace the bulb and see if it works. I doubt that it will. If not unplug the unit and remove the exterior case. Locate the secondary fuse and replace it with the same size and rating. Plug in and try but be prepared as it may do the same thing again. I am not sure what you mean by 'lay up' your unit. If it was not running (heating) it should not be the magnatron. Sounds like the bulb blew taking out the fuse which would cause the other problems you described following the flash. Good luck.
Jun 12, 2007 | Kenmore 63672 Convection/Microwave Oven
Air Tools & Compressors Logo
131 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
