Question about Dishwashers
Machine has burning smell while operating. Removed belt and had a lot of black residue. Motor also is difficult to turn by hand.
  • 715 Answers
Your motor is on its way out bad bearings
Posted on Nov 13, 2009
The know on the side of the machine that rotates the needle when turned by hand is tight, hard to turn. What do I need to do to fix it or adjust it so that it turns without having to force it to turn?
I do have a couple of suggestions but would feel better if you'd first e-search Sharpe's site for your model's "Service manual"-a manual for simple repairs and how your machine disassembles and runs. With it you'd be a step ahead on a lot of your machine's maintenance and trouble issues!Don't give up too easily on your search.Sharpe likely sold the right to make your exact machine to other machine makers. These companies may have a Service Manual if Sharpe doesn't. You may be able to save and print from a PDF file. I'm not "up" on the newer machines so am assuming you have a belt drive machine: a rubber-like belt that is turned by the hand knob as well as the motor.What your describing is likely a too tight screw that secures the knob to the belt revolutions' workings (especially if the knob has been removed before). If your Sharpe knob pulls (toward your hand) to stop the needle for bobbin winding and THAT's too tight, then you have another screw in the knob to slightly loosen! In both cases, carefully disassemble the knob and look for the problem screw(s). Should the machine smell like burning rubber or make a screeching sound at high speed you'll need to change the belt and adjust it-probably with a professional.Old belts do get stiff, cracked and sometimes ragged so a new belt can make the motor run quieter and smoother.Hope this helps you especially, maybe others as well.
Jun 08, 2014 | Euro-Pro Shark 60 - 384
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
Drum rotates and then motor locks up. Burning smell comes from machine with continued operation. Drum rotates free by hand. Drive problem or motor?
replace your belt ... the motor does not smell like burning rubber, the belt will exzude that odor.
Pop the top ... remove the front ... use care with the door switch wires.
the drum will come free of the unit.
Put the new belt over the drum, through the tensioner on the bottom, around the motor pulley.
You will need help ... put the drum back on the wheels inthe back and replace the front ... snap the top down
while it is apart, clean the exhaust system completely
Nov 02, 2009 | LG WM0642H Front Load
My dyson dc14 has a strong burning smell
A DC 14 has two belts - one that connects the motor ourput to the clutch mechanism (the dial that lets you turn off the brush rotation completely is part of the clutch mechanism), and another that connects the clutch to the brush bar.
Unfortuneatley, the one that connects the motor to the clutch is hidden under a plastic cover so is very difficult to check.
With the machine running, and NOT in the upright position (i.e. as if you were vacuuming a floor), make sure the brush bar is actually rotating. If it isnt, you need to check both belts and the clutch. Due to the cover being held by three "Torx" screws, one of which is very difficult to get at, this isnt easy.
If the brush bar is rotating, then the burning is an indication the motor is about to fail. Motor replacement is possible depending how good your DIY skills are, and again you'll need "Torx" drivers to dismantle it. Website www.dysonmedic.com has some very good info.
Oct 10, 2009 | Vacuums
Will not turn on. Smells like burning rubber. May have overloaded. What is broken?
There may be a problem with the motor or with the drive train. If the washing machine uses a belt drive, you might need to replace the belt. I found a new one for my friend's washing machine at autozone for $5. If the belt is ok or the machine uses a gear drive, there might be a problem with the motor. If the motor doesn't turn but still causes a burning smell, it's either jammed or has a problem with the starter circuit. A motor that big takes a a big jolt to get started. I fixed a newer washing machine by opening up the control panel and reconnecting the starter circuit for the motor that come off. The motor was making a burning smell so we knew it was getting power, but we knew it wasn't jammed because I stuck my finger in the water pump (for goodness sake unplug the stupid thing) and could easily turn the motor with my finger. If you think the problem is with the motor, double check all the motor's connections and realize that it may have two or more seperate cables connecting it to various places. If the motor gets hot, turns freely, and won't start, you could also try testing or replacing its starter capacitor, a black tube connected to or attached to the motor.
Oct 01, 2009 | Washing Machines
Kenmore Washer has Elect smell; no pump, spin, or agitate.
The ECU/Controller has failed. Replacement is your only option.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Washing Machines
Machine has burning rubber smell when running. The drive unit seems difficult to turn by hand but I have no prior reference. How much resistace is normal to hand turn the drive gear assembly?
It requires a quite of bit force to turn it. The rubber smell is probably the belt slipping and overheating. It should be tightened before it breaks.
May 02, 2009 | Maytag Washing Machines
Dryer not turning. belt is good
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Dec 17, 2008 | Whirlpool Dryers
Dryer does not tumble, but heats up
Click here for a belt installation diagram.
  • Remove the belt.
if this helps please vote me a fix ya
Jul 15, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
