Question about Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400 Psi Gas Pressure Washer
No pressure. Have cleaned inflow filter, checked water supply and cleaned and lubed the uploader valve.
  • 251 Answers
If there is water comming out of the back of the pump then your piston seals need replaced , if the lace vibrates then one or more pump valves are blocked ) theres 6 in total /in pairs ) , try running the machine with no hose/lance connected as the lance nozzle often blocks up /malfunctions
hope this helps , if it does please vote
Posted on Nov 13, 2009
What does error code ie indicate?
IE error mostly means not filling completely with water or very slow fill
Jan 31, 2016 | LG WM2688HWM TROMM SteamWasher
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
Water fill
Possible failure of the inlet valve and so it is necessary to see the inflow pressure . If this is good then when the machine is switched on then the voltage to the inlet valve must be checked, if there is no voltage then the program controller unit is faulty. If present the inlet valve is faulty, try and remove , clean or replace .Click on : inlet valve replacement
Mar 14, 2012 | Frigidaire ATF6000ES Front Load Washer
How to open the housing on big blue 20 to change filter
The best way to do this is to shut the incoming water supply off. Open the closest cold water faucet to relieve the water pressure. Shut off the outlet valve. You will need a BB wrench. Push the RED pressure relief button on top of filter as you turn clockwise on the wrench. Lubricate the o-ring with silicone lube, clean filter housing and re-install filter. Only tighten housing hand tight.
RJ
Mar 05, 2011 | Culligan 34" Whole House Water Filter...
My Honda XR2750 pressure washer doesn't seem to be spraying a full capacity. Is there a blockage and /or filter I can clean?
Usual cause is the water admitance valve that regulates the pressure by admitting more or less water.
Remove the valve parts and clean the bore with crocus cloth on a dowel rod. Replace the O rings and lube with plumber's grease.
Re-assemble.
Jul 15, 2010 | Garden
Pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
May 16, 2010 | Honda Pressure Washer PSI 3000
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Not filling with water to wash
(1) Fill valve failed, check and replace
(2) Fill valve filter blocked , take off back supply hose and clean out mesh filter (Turn off water supply first and have a cloth handy to catch water remaining in hose under pressure)
Nov 05, 2009 | Dishwashers
No inflow of water
Hello, your problem is going to be with the inlet valve. Remove the panel at the front bottom of the dish washer, turn the water and power off. You will see the inlet valve normally on the left side underneath your dishwasher (sometimes on right) connected to the water supply. Remove the water supply hose/pipe and then remove the wire harness from the valve. Now you can remove the valve from the machine. Just inside the inlet there should be a screen...check this for debris. If debris found clean out and reassemble, If no debris replace the valve and then reassemble. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Aug 26, 2009 | LG Dishwashers
Intermittent hot water valve not opening
problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Dec 17, 2006 | Miele Novotronic W1918A Front Load Washer
Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400 Psi Gas Pressure Washer Logo
184 people viewed this question
Top Alfred Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Alfred Measuring Tool and Sensor Expert? Answer questions, earn points and help others
