Question about DeLonghi EC701 Espresso Machine
DeLonghi EC701 Pump out
I am located in SW Denver Colorado and have a DeLonghi EC701 that appears to have a pump not work.The pump seems to just very, very slowly drip espresso...but the steamer works just fine.
I contacted Delonghi customer service but they were NO help at all...not under warranty. There is a service location listed about an hour from here, but they are not responsive.
Any ideas? I really like this machine, but am thinking I have to buy new unless I can get this fixed.
Thanks,
Need Caffeine in Denver
  • 4 Answers
I had the same issue. Scale build up in the port that routes water to the boiler outlet for the coffee filter basket. Frother tube was fine.
I used CLR to open it back up. Used 1 part to 4 of water and ran a whole reserviour through the unit. At first, it only dripped and then finally it blew open when the CLR dissolved the scale.
Make sure to run lots of clean water through the unit after so that you don't end up drinking acid with your next cup. I ran about a gallon through to rinse it out.
Posted on Mar 26, 2008
Ec702 delongi is not pumping for espressor but steamer works
first perform a chemical cleaning, place the chemical in the water tank and then this hot place to make coffee, so that the chemical clean pump and piping hot water, repeat this until you spend all the water,
if not repaired you may have problem with the water pump, solenoid or inlay is great need to remove the tubes and clean them out
ramon
nomarpartsupply.com
Sep 01, 2014 | DeLonghi EC701 Espresso Machine
I have a delonghi EC701 machine. It was over heating and after making a cup I left the machine on. a few minutes later it blew the ring fuse and now it will not heat up the water. The machine seems o get...
First, I'm not a delonghi technician. But I've worked on similar units.
* Table top brewers usually have water reservoirs that require monitoring and refilled when they get low (especially after brewing)
* It's possible the water level sensor is stuck (in the water reservoir) which tells the machine that it still has water and keeps heating the tank(s). Clean tank as described in your manual. You will still need servicing to check and replace fuse(s).
* There is usually two tanks/heaters in this type of table top machine (larger pro models use one large tank) The thermal limit fuse on one or both are probably blown. Call vendor for service.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
Jan 17, 2018 | DeLonghi EC701 Espresso Machine
Fuel pump
The performance of an electric fuel pump can be tested several ways. The easiest and most effective of which is to test fuel pressure and volume at the vehicles fuel pressure test port. Normally located on the fuel injection rail. A more direct method would be breaking the fuel line somewhere between the pump and the fuel filter and placing your gage there for a test.
Jun 02, 2009 | 1994 Chevrolet Suburban
How do i clean the pump for the delonghi ec702?
you have t use a discaller for expresso machine not vinergar not strong enought follow the instruction on the discaller put product inthe machine with the water start the the machine after a few second turn it off for 10 minute time for the discaller to work repeat untill empty rinse very good that it do that every 3 month thanks pierre
Dec 13, 2008 | DeLonghi EC701 Espresso Machine
Finding Amana Dealers for the Denver area
Mountain Maytag Home Appliance Center
1571 S. Colorado Boulevard
Denver, Colorado 80222
(303) 512-0700
Jul 27, 2008 | Amana Refrigerators
DeLonghi BAR 4 Espresso Machine User Guide
Go to http://www.delonghi.com/Int/USA/customer.html
Choose the Customer Service tab. On the left, notice a link to Instruction Manuals - follow that link and choose your model by following the products tree. It will give you a pdf file of the instruction manual for download.
Mar 24, 2008 | DeLonghi EC701 Espresso Machine
DeLonghi EC701
Could be scale build up. Do you have well water? You should run a descaler or white vinegar through the unit often to keep the boiler outlets clean.
Unless you are saying that the pump just doesn't run, ie, no noise, vibration, etc. Then, thanks for the warning that their pumps are bad.
Dec 30, 2007 | DeLonghi EC701 Espresso Machine
No water ever makes it through the pump
I just got mine working again. There was scale in the outlet port for the coffee basket.
Try cleaning by running through a solution of CLR and water (1 to 4 parts) and keep running until the blockage dissolves and flow is restored. Then run another solution again just to clean it for good.
MAKE SURE TO RINSE OUT THE RESERVIOUR VERY WELL. Should run clear without foam after about a gallon of clean water.
Nov 22, 2007 | DeLonghi EC701 Espresso Machine
DeLonghi Dehumidifier pump out failure
I have the same problem. Very annoying. My suggestion is to go to your nearest dealer and throw the unit through their front window.
Aug 02, 2007 | DeLonghi DE500 Dehumidifier
DeLonghi EC701 Espresso Machine Logo
1,107 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
