Question about Microsoft Xbox 360 Console
Console will not read disk. always says open tray after mulitble times of opening and closing games seem to pull though and work. is it the laser or spinner
    Problem Solver:
  • 11 Answers
Well, it could be your disk is scratched (but im sure you didnt post this just for someone to say you have a scratched disk so...lol) the best do it yourself solution to this problom is to take your 360 apart and replace the disk drive all together. You could find the parts on ebay or whatever,...it is very easy to replace the disk drive, pretty much once you get the case off...(hint: only remove the long screws) cuz those are the ones hold the case together..pretty much after that you just remove the disk drive, remove the two cables that are attached to it, and put in the new diskdrive..oh and make sure you get the right disk drive in there, Microsoft used 2 diffrent brands or disk drives (im not sure if they make a diffrence but better safe then sorry) it will say which one you got on the disk drive when you take it out... OH!! and before you do anything, call 1800 4myxbox and SEE IF YOU HAVE ANY WARRENTY ON THE CONSOLE, cuz if you do, the repair will be free. hope this helped ya...Later ;)
Posted on Nov 13, 2009
Will not read disks. Cycled power usally worked not this time.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
Dec 30, 2010 | Microsoft Xbox 360 Console
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't read.by the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Oct 25, 2010 | Microsoft Xbox 360 Console
A Game I bought will not work.
Check the inside ring of the disc for a v shape deformation or cracks. also look for dimples. That is usually the problem with some older 360 games.
May 27, 2010 | Video Game Consoles & Games
Open tray issue
This can be caused by a dirty laser in the drive. Try cleaning the laser with a q-tip and alcohol. If this does not fix the problem, the laser may need to be replaced. Contact Microsoft and see if the unit is still under warranty.
Feb 11, 2010 | Microsoft Xbox 360 Console
Open tray on xbox when it's closed
when the tray is closed and it does not
see a cd it should say open tray
The problem weak or dead laser
laser are chep 30.00- 40.00
and not to hard to swap out.
second it may be a bad drive motor
or bad spindel motor .in that
case you will to buy a new
drive and swap out the P.C. board
from the old drive to the new one
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Disk tray for xbox 360 problem
try blowing in the xbox 360's tray in side where the laser or let it sit open tray for a little bit do things on it and then close tray it might work it does for my xbox most of the time im 12 yrs old
Jun 28, 2009 | Microsoft Xbox 360 Console
Games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Jun 01, 2009 | Microsoft Xbox 360 Console
Xbox 360
This problem is almost always a Laser read error and 9 out of 10 times its just a dirty laser but here is the real problem you can't fix it with one of those generic DVD disk cleaners they almost always fail. You ready for the worst part, if still under warranty your going to have to send it back to Microsoft to get it fixed. Your now on a downward spiral where the laser will continue to get even dirtier and fail at a greater and greater rate. Some good news though if console is out of warranty because doing this simple fix will void it. All that needs to be be done most of the time and I repeat most, but not all the time, is dipping one end of a Q tip in Isopropyl Alcohol, rubbing the laser lens a few time in a clockwise motion, flipping the tip over to the dry side and doing the same thing for about 15 to 20 seconds. Use very little pressure to do this because while your doing it you will notice the laser lens is riding on a mini shock absorber system and pressing down to hard will throw this out of alignment and then you will really have a laser problem. Obviously this fix requires you to disassemble your 360 which will void any active warranty left on device. I wont go over how to disassemble the console here because there are thousands of guides on line to give you that info. When device is open simply disconnect the two cables attached to the back of the drive, one a standard SATA connection the other a proprietary power connector which you can pull straight out just like the SATA cable. Depending on what type of drive you have inside, "The most common drive that experiences this problem is the Hitachi GDR-3120L" you would then proceed to open DVD drive player to access the laser unfettered so you can clean it.
Aug 27, 2008 | Microsoft Xbox 360 Console
Xbox 360 open tray error
How I worked around the "Open Tray" problem, where the game discs were not being recognized:
1. Open tray
2. Unplug power cable while tray is open
3. Plug in power cable
4. Power on console - tray closes
5. Open tray
6. Insert disc
7. Try your game
Good luck! Source: Someone else mentioned this in a forum somewhere, however I don't recall who it was or which forum. I'm just trying to get the word out so people don't send in their XBOX for repair, or open the case and void the warranty if this workaround resolves the problem.
Mar 25, 2008 | Microsoft Xbox 360 Console
Open tray close tray reading open tray
call xbox customer support at 1-800-4MY-XBOX
Jan 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
95 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
