Question about GE WSXH208A Front Load Washer
Can the shaft with 3 legged brace be bought w/o the basket and if so what price range?-Thanks-Ben Dresser bendresser@cs.com
    Problem Solver:
  • 12 Answers
It Can we call it a spider, £35 quid with new bearing n seal kit
Posted on Nov 13, 2009
Show me how to repair a cv joint Saturn vue 2006?
Transaxle Removal & Installation
Fig. Disconnect the shift control cable (3) from the range select lever (4)
  • Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2).
    Fig. Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2)
  • Safely support the engine.
  • Remove the transaxle mount to transaxle bolts.
    Fig. Remove the transaxle mount to transaxle bolts
  • Remove the transaxle mount to frame rail bolts.
  • Remove the mount from the engine.
    Fig. Remove the transaxle mount to frame rail bolts
  • Remove the left transaxle mount
  • Raise and safely support the vehicle.
  • Remove the front wheel and tire assemblies.
  • Remove the splash shield.
  • Remove the bolts (2, 3) from the transaxle brace.
  • Remove the transaxle brace (1).
    Fig. Remove the bolts (2, 3) from the transaxle brace
  • Remove the starter.
  • Mark the relationship of the flywheel to the torque converter for reassembly.
  • Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
  • Remove the torque converter to flywheel bolts.
  • Remove the nut holding the transaxle cooler line retainer to the transaxle.
  • Disconnect the transaxle cooler lines from the transaxle.
  • Disconnect the Vehicle Speed Sensor (VSS) wiring harness from the sensor.
  • Remove the steering gear intermediate shaft pinch bolt.
  • Disconnect the tie rods from the steering knuckle.
  • Disconnect the stabilizer shaft links from the stabilizer shaft.
  • Disconnect the ball joints from the steering knuckles.
  • Remove the frame.
  • Disconnect the wheel drive shafts from the transaxle.
  • Support the transaxle with a suitable jack.
  • Remove the lower transaxle to engine bolts (5, 6, 7, 8).
    Fig. Remove the lower transaxle to engine bolts (5, 6, 7, 8)
  • Separate the engine and the transaxle.
  • Remove the transaxle from the vehicle.
  • Flush the transaxle cooler and the lines with J 35944-A, Transaxle Oil Cooler Flusher.
  • Remove the following only if replacing the transaxle.
    1. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
    2. Remove the PNP switch.
    3. Remove the transaxle mounts.
      Fig. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
  • To install:
    1. Install the following if previously removed
      1. Install the shift cable bracket (2), bolt (3), and nut (1).
      2. Tighten the bolt (3) and nut (1) to 16 ft. lbs. (22 Nm).
    2. Install the PNP switch.
    3. Install the transaxle mounts.
    4. Position the transaxle in the vehicle.
    5. Install the lower transaxle to engine bolts. Tighten the bolts to 55 ft. lbs. (75 Nm).
    6. Install the wheel drive shafts to the transaxle.
    7. Install the frame.
    8. Lubricate the transaxle cooler pipes before inserting into seals.
    9. Connect the transaxle cooler pipes to the transaxle.
    10. Install the transaxle cooler pipes retainer nut. Tighten the nut to 62 inch lbs. (7 Nm).
    11. Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
    12. Install the torque converter to flywheel bolts. Tighten the torque converter bolts to 44 ft. lbs. (60 Nm).
    13. Install the starter.
    14. Install the frame.
    15. Install the steering gear intermediate shaft pinch bolt.
    16. Connect the ball joints to the steering knuckles.
    17. Connect the stabilizer shaft links to the stabilizer shaft.
    18. Connect the tie rods to the steering knuckle.
    19. Connect the wiring harness to the VSS.
    20. Install the transaxle brace.
    21. Install the transaxle brace bolts. Tighten the bolts to 39 ft. lbs. (53 Nm).
    22. Install the front splash shields.
    23. Install the front wheel and tire assemblies.
    24. Lower the vehicle.
    25. Install the left transaxle mount.
    26. Install the upper transaxle to engine bolts and stud. Tighten all of the bolts and stud to 55 ft. lbs. (75 Nm).
    27. Untie the radiator, air conditioning condenser, and fan module assembly.
    28. Remove the engine support fixture.
    29. Connect the transaxle wiring harness to the main transaxle electrical connector, and the PNP switch.
    30. Install the shift control cable to the shift control cable bracket. Ensure the cable retaining clip is fully seated.
    31. Connect the shift control cable to the range select lever.
    32. Connect the air duct hose to the intake plenum.
    33. Install the battery tray.
    34. Inspect the transaxle fluid level.
      NOTE
      It is recommended that Transmission Adaptive Pressure (TAP) information be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, the ECM, PCM or TCM will need to relearn TAP values. Transaxle performance may be affected as new TAP values are learned.
    35. Reset the TAP values
    Jul 22, 2014 | 2006 Saturn Vue
    Removing stuck shaft from Cabrio Washing Machine
    use a bottle jack, brace the basket and use the hydraulic power of the bottle jack (halfords sell them cheap)
    Dec 07, 2013 | Whirlpool Washing Machines
    Circo Chloe and Conner 3 drawer dresser assembly instructions
    You could try contacting the manufacturer directly to ask them for assembly instructions. Alternatively, you can go back to the store where you bought the item and see if they can assist you.
    Sep 29, 2012 | Circo Kids Dresser: Chloe & Conner 3...
    How much does a Deep Fry Basket, 6" x 17-1/2" x 16-3/4" cost?
    Itdepends on the quality of the basket but prices range from around $70 to $120.Here is a link http://www.amazon.com/Dean-Fry-Basket-17-1-16-3/dp/B001BR2D8I
    Jul 16, 2012 | Dean Guitars Fry Basket
    Need assembly instructions for gardenline double glider bought at Aldi.
    Hi, I know this probably won't help whoever posted this because I'm really late, but it will helpfully help out those still searching online.
    1. Attach one leg brace (E) to the leg (F) using two M6*40 screws (K), four washers (P) and two nuts (Q). Repeat this step to attach the other leg (F). See Fig.1
    2. Attach the other leg brace (E) to the legs (F) using one M6*40
    screw (K), two washers (P) and one nut (Q). Repeat this step to
    attach the other leg (F). See Fig.2
    3. Attach one rocker connector (G) to the leg (F) using one M6*55 screw (M), two washers (P), one spacer (O) and one nut (Q). Repeat this step to attach the other leg (F). See Fig.3
    4. Attach the other rocker connector (G) to the leg (F) using one
    M6*60 screw (N), two washers (P) and one nut (Q). Repeat this
    step to attach the other leg (F). See Fig.4
    5. Attach the left arm (B) to the chair back (C) using two M6*35
    screws (J) and two washers (P). Repeat this step to attach the
    right arm (A). See Fig.5
    6. Attach the chair seat (E) to the arm front side using two M6*20 screws (I), two washers (P) and two large washers (S). Attach the chair seat (E) to the arm rear side using two M6*35 screws and two washers (P). See Fig.6
    7. Attach the assembled chair bucket to the lower end of the
    rocker connector (G) using one M6*50 screw, two washers (P),
    one spacer (O) and one nut (Q). Repeat this step to assemble
    the other three connection points. See Fig.7
    8. Fully tighten all screws using wrench (T) and Allen Key (U).
    Cover all hardware with screw caps (H) and nut covers (R)
    respectively. See Fig.8
    May 08, 2011 | Garden
    Front end problems comming out my ying yang 2006ho 12000kms have replaced the front shaft 4times wears out now the stob shaft comming out of my front rearend is worn to bad to put any shaft on and Polaris...
    try ebay, see lots of good prices there, lots of free shipping, just enter the year and make and what your looking for in the search bar. thats where i get my parts. polaris wants 171.00 for a new starter bendix, just bought one brand new from ebay for 31.95 free shipping, claims it is even better than OEM
    Dec 17, 2010 | Polaris ATV
    11027062600 KENMORE ELITE problem. Sounds like a popcorn machine. Kids wash coins and so forth. How do i get them out?
    Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
    The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
    Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
    the rear tub.
    Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
    the front tub removed. Go ahead, remove the pulley and bolt, and if
    the basket comes out, then check everything out.
    If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
    and tub assembly.
    Front - loader: Remove Bellow
    http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Apr 03, 2010 | Kenmore Elite Professional Style 51423...
    The washer clunks during spin cycle. I removed the back and found some pieces of plastic from the outer drum enclosure. Other than that, everything seemed to be intact. The "shocks" or feet were not broken...
    If the inner basket has broken off on one of the three braces on the back side where it is welded to the main spindle shaft that goes through the outer shell and bearing, you will need to replace the spindle and probably the inner basket. Some come together, some can be bought seperately and bolted. Not sure which yours is. Most people go out and replace unit rather than attempt ths repair because of cost if done by a appliance business. It is a complete tear down, and part or parts are expensive.
    If you grab the inner basket and try to move it side to side, it should be solid.. The whole tub assembly can move while your doing this, but the inner basket should be solid in the back bearing
    Just one idea..
    Jan 13, 2010 | Frigidaire Washing Machines
    How can i download adobe photoshop 7.0
    photoshop 7 is out-dated now and i dnt thnk you can find it on internet. wht abt givng a try to CS, CS2, 3 or 4? You can download portable versions here. CS 3 xtended: http://kewlshare.com/dl/28feae4e76ab/Adobe_20Photoshop_20CS2_209.0.2.rar.html password: projectw.org
    CS2: http://rapidshare.com/files/165130635/portable_Adobe_Photoshop_9.0_CS2_Portable_Espa_ol.rar http://rapidshare.com/files/32692207/Photoshop_CS2_Portable.rar
    Sep 10, 2009 | Adobe Photoshop 7.0 for PC
    GE WSXH208A Front Load Washer Logo
    100 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
