Question about Linksys Wireless-G WRT54G Router
Having trouble connecting. I see my encrypted router, but it shows as "unknown." And when I try to connect with it, connection fails. Says not in range although I'm in my own house. :o)
  • Linksys Master
  • 2,263 Answers
You said that you can see the wireless network but it shows as unknown network
I think SSID broadcast on your wireless network must be disabled.
You will need to enable the SSID broadcast of your network.
Also try to change the wireless channel on the router.
WRT54G router's IP address will be 192.168.1.1. if you have not changed it.
Do you have any other computer connected to the router woth the ethernet cable ?
If you do not have the computer connected to the route then connect 1 computer to the rotuer with the ethernet cable.
Do not change any wireless setting on the wireless computer.
You will need to open the set up page of the router
Click Here for more info about how to change the wireless settings
Posted on Nov 14, 2009
    Guru:
  • 1,738 Answers
Linksys wireless firmware has not gone very far. I personally use a third party firmware www.dd-wrt.com. After I installed that I can adjust the power and make the range go farther and secure it. I can go down one block and still get my signal.
Posted on Nov 19, 2009
  • Linksys Master
  • 32,281 Answers
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up. Concrete floors and walls with metal foil insulation will stop wireless signals radiating out.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is being used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Nov 13, 2009
Having trouble connecting 2 laptops and ipad towifi router...belkinN450
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 03, 2013 | Belkin N450 Wireless N Router
Hey ! I've got a DELL Wireless 2350 Broadband Router and it's working just fine. Recently I purchased a wireless printer (Samsung ML-1856W). I get the printer to work via the network if I...
My first thought would be to try different forms of encryption on your router. It's possible that your printer may not support the type of encryption you're trying to use which may be causing it to have trouble connecting. For example, if you're using WPA encryption, try switching to a WEP key instead. You can change all of these settings from your Wireless Router's configuration page.
Jul 24, 2011 | Dell Wireless 2350 Router
Im having trouble connecting my laptop to the wireless router, it shows on desktop but not on laptop nor the PS3?
Chances are you are using WPA2 encryption, the PS3 and laptop may not have compatible wireless interfaces.
Drop your encryption to WPA.
Jul 21, 2011 | Belkin F5D7234-4 Router
I have a WZR-HP-G300NH router and am having trouble connect my ipad to it. Ipad is asking for a pass word. How do I fix it?
I recently got this router and had trouble keeping a wireless connection to my ipad. On the router, I set up security with wpa2/psk and set a password and was able to enter that password on the ipad and got a connection but only briefly. After repeated losses of connection, I took encryption off and now it works fine. This is a terrible solution though and eventually want to get encryption back on .
Sep 14, 2010 | BuffaloShop Buffalo Technology WHRG300N...
I have a mac and am having trouble with the
Whenever I have problems like you describe, I try to simplify. Remove the encryption key & see if your mac will connect. If YES, then add a simple key. I go with all numbers. Add complexity as you succeed. At the end of this process, reconfig all the other devices.
Jun 04, 2010 | D-Link AirPlus DI-524 Wireless Router
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
HOw do i uninstall the drivers?
Vista isn't particularly good at telling you exactly WHY despite its pretty "diagnostics".
First try turning any encryption/security off on your router and see if you can connect. If you still can't connect with no encryption, uninstall the device and reinstall it. If you can connect, then the problem is with the encryption. Make a careful note of exactly what settings your router is using and make sure you give them fully to Vista.
May 26, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
XBOX Live problems with Belkin N1 router
I suggest setting this up with a WPA encryption rather than WEP encryption. This should get ya setup without a problem. Also, I've noticed live to be a bit buggy since Christmas. If you continue to have troubles after trying this call 800-4my-xbox. The recording will tell you if they are having network issues.
I bet this helps!
Dec 31, 2007 | Computers & Internet
Router connections
If you have a laptop in home 2 that is able to connect with NO issues whatso ever I would almost think its a security issue... Do you use the same kind of encryption on both home 1 and 2? (ie WPA or WEP)
Wireless connection
Try turning off encryption on the router. If you can connect after that it is an encryption problem.
Dec 25, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
128 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
