Question about Explorer Appliances Go Diego Rescue Cell Phone Knows Your Name +18 Mos Toy
I have tried to program my phone 3 different times but it keeps saying the wrong name
  • 32 Answers
Its a Diego phone what do you excpect
Posted on Nov 13, 2009
GE 7 day timer 15091 set day and time and set programs correctly. Timer works right for several days then timer resets itself and loses time and programs. This is the third GE timer that I have...
1) If you have chronic problems with electronic timers, then circuit is suspect. Buy cheap circuit analyzer and plug into same outlet. Try timer on different outlet on different circuit breaker. Change Load (lamp, fan) to see if same problem occurs with different load.
2) Maximum load for GE 15091 is 600 watts incandescent. There is no HP rating, so timer probably not made for motor loads since motors draw high initial amperage. For heavier duty timer, with 1250W incandescent and 1/3 HP, select Woods 59201.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
3) I have tested GE timers. They are made well.
The 15091 is sold under different brand names, so it is successful design that's been around a while.
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Vacuums
I am also trying to change the extension names but for some reason when I press program the only thing that shows up is "Program No?" what do i do next?
Start by pressing ** and see what the display shows. If it doesn't show anything but beeps, then you have the wrong phone. Try looking for extension 101 or the first phone in the system.
When you find that phone and press program **1234, you'll go into programming. Dial 004 and press ENTER. If you press ENTER again, you'll be looking at extension 101, or you can dial an extension and be looking at a name. Now you spell out the name on the keypad using the letters and the arrow key if necessary and press ENTER (the center of the Navigator button) to store the name. Notice that the 4th time you press a 3 letter ALPHA key, you will get lower case letters. Punctuation is under the 1, * and # keys and Q appears under the 1 and 7 keys :-)
Next steps you to the next extension and you can just pick up the handset and set it back down to end programming.
Carl
Oct 26, 2010 | Panasonic KX-T7633 Corded Phone
I'm having trouble in changing the time on the Partner 18D. this is what i do: ) at station/ext.10 press feature,0,0 2)press the left intercom 2 times 3) enter #103 and once i press the 0 on the #103 the...
A Partner system is pretty foolproof, but Feature 10 is a Message Waiting programming button. Are you keeping the handset in the base?
It's possible that your # key is stuck. If you're truly at x10 and it's not working, try another command like #407 and see if List Number shows up. If it does, then 103 should work, if not, try another phone in that location.
Carl
Dec 21, 2009 | Lucent PARTNER18 Corded Phone
Program Extension Name and change time on phone.
Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Sep 23, 2009 | Panasonic KX-T7633 Corded Phone
When I try to send a picture I scaned to an email it keeps saying something about a pop 3 server not found
Do you use outlook express or outlook for your email or a server based email. If you use a server based email the scanner software is opening the program that resided on your pc which is not set up for emailing. That is why it says the pop 3 server is not found. You will need to attach the picture file to your email from within your hotmail or google or what ever web based email you use. Then send it.
Aug 02, 2009 | Lexmark X2600 InkJet Printer
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
Setting the time
Your phone can be used on different Panasonic phone systems and each one programs differently. You were probably reading instructions for the wrong system. You need to determine which system you have (it's not a phone) and find the directions for that.
Here is a link that has time change instructions for many Panasonic systems: http://www.tel-programmer.com/time_setting.html
Nov 13, 2007 | Panasonic KX-T7731 Corded Phone
My samsung e 370 keeps saying cannot resolve host name
If this problem is coming from a long time then it is the problem of ur area's network. Call ur service provider for the same. Might be the problem in a particular website.Try different sites.
Oct 22, 2007 | Samsung SGH-E370 Cellular Phone
Changing the names on extensions
Fuction
266344
Pw: 23646
Terninals & Sets
Show set: (type your extension in)
Your extenstion shows: Your Name or Name You want to Change
press top right Arrow button
Capabilities...
Bottom right Arrow button
Name:
CLR Change
Press Change, then use the keypad to type in new name
Prees bottom Arrow Button again, then Release button.
Sep 12, 2007 | NorStar T7316E Corded Phone
Explorer Appliances Go Diego Rescue Cell Phone Knows Your Name +18 Mos Toy Logo
37 people viewed this question
Top Explorer Appliances Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Explorer Appliances Toy Expert? Answer questions, earn points and help others
