Question about Cobra Radio Communications
I have a Cobra 148GTL with a 5 pin side mount mic. My problem is that the radio powers up and all I get is a static type noise but no recieve and when I key the mic the meter shows I'm sending a signal but I can't be herd.
    Sergeant:
  • 172 Answers
Sounds like a bad mic....At the 5 pin end u will see a small screw take out that screw and slide the pin cover back and you will see the 5 wires going to the pins my bet 1 or more of those ends are broken all you ned is re sod. them and all will be good .....I buy alot of broken mics and all i need do is fix the wires easy fix .....
Posted on Nov 13, 2009
The wiring came off and don't know howe they go by color it'got5 places to salder wires are r/b/or/b
If your asking about a Cobra radio then these links will have the pin-outs plus wiring color code for different mic's.
I had to guess what you was asking for as your question was kinda vague. And a Cobra 29 is a 4 pin mike, not 5 pin.
The 148 - 142 were 5 pin. I'll include it also.
http://www.cbtricks.com/radios/cobra/148gtl/index.htm Cobra 29LTD ST 29WX ST
Aug 13, 2015 | Cobra 29 LTD CB Radio
Need Cobra 148GTL with Cobra HG M75 pin-out color code
1audio. 1red
2shield. 2shield
3receive. 3blue
4switching. 4white
5transmit. 5black
Hope this helps
Jul 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I have a 1990 cobra 148 GTL with 5 pin side-mounted mic. I recently bought a Barjan 5 pin noise canceling mic. Is the mic compatible with my cb, or do I need to change the wiring? Larry
The wiring is not likely to be the same.
The information on the radio is here:
You will likely need to open up the mic to identify what your wires connect to to determine the correct oreintation. it is possible too you may find one of the models listed was used by Barjan and is nothing more than a rebranded microphone.
Feb 17, 2012 | Cobra Radio Communications
I have a cobra 148gtl with 5 pin side plug for mic.Im trying to wire a superstar dm 1000 echo mic to it,red,yellow,blue,white,& unsheilded wires dont know were they go.???????
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
Jan 20, 2010 | Cobra Radio Communications
5 pin mic
All "older", "real" or "desirable" Cobra 148 GTLs came with side-mounted 5 pin microphone sockets. For wiring information, see...
http://www.offroaders.com/info/tech-corner/reading/mic-wiring.htm
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
No recieve on virgin cobra 142 gtl,
seems to me that the audio ic of the cobra 148gtl brokedue sudden change of voltage from power suplly or flactuation. ta7222p
Jun 07, 2008 | Radio Communications
Radio Communications Logo
125 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
