Question about Sony Handycam DCR-TRV460 Digital Camcorder
Playback problems started suddenly
I have about 125 tapes, half of them D8 tapes recorded with the DCR-TRV460 and half of them 8mm and Hi-8 tapes recorded with an older Sharp camera I no longer have. Up until now, all of them would play fine in the DCR-TRV460. I have started going through all of them to collect the best footage and copy it to my computer to make DVDs.
Everything went fine for the first 10 tapes or so, then all of a sudden today nothing will play right. 8mm and Hi-8 tapes are playing with lots of vertical white lines which are constantly shifting around, and there is no sound on these tapes. D8 tapes will play, with a clear image and sound, but the motion is very jerky, not smooth at all.
I ran a cleaning tape through it and that made no difference. What cause this sudden change in the camera? I didn't drop it or anything. Is this going to mean an expensive trip to a repair shop or to Sony? Any suggestions would be appreciated. Thanks!
  • PenName Apr 29, 2008
    I have exactly the same problem; same circumstances (mix of D8 and Video8 tapes I am trying to transfer to DVD, so that I can get rid of this "tape" nonsense), same symptoms (vertical lines, no sound on Video8 and jumpy playback on D8), and my only hope was that a cleaning tape would fix the problem (I just ordered one.)
    My problem started when I tried playing back a Video8 tape. The tape was at a position close to its ends, it played fine. I rewound to about halfway of its length, and it played fine. When I rewound it further to about 25% of length and played it I noticed the very prominent vertical lines, and lack of sound. I rewound further, tried another tape, and another. The lines are gone, but picture with Video8 is grainy and there is not sound. I then tried a D8 tape, and for a while the LCD was blue, and the counter did not work. I tried several different tapes, and the camcorder seemed to come back, but then I tried a Video8 tape with no success, and the problem came back for D8 as well. Toward the beginning of the D8 tapes the camcorder handles them as Hi8, if it's about half way or beyond tape length it handles them as D8, but the payback is jumpy.
    I still have about 20 tapes 75% Video8, 25% D8, very frustrated, and have sworn never to buy anything SONY (This is not the first time a Sony product from which I expected a lot has turned to be a piece of rubbish.)
  • sunbroesche Nov 07, 2008
    I also have a Sony DCR-TRV460 it will record and sometimes playback on the tv but not on the camera. I also have purchased a tape cleaner and tried that and still cannot playback. It seems to record good but no playback?
    thanks,
    sunbroesche
I had the same problem. I fixed it by gently dropping the camcorder on the carpeted floor. I know it sounds silly, but it really works. I've had to do it twice, and it worked both times. I hope it works for you.
Posted on Nov 10, 2008
  • yawehlives Jul 03, 2011
    I had the same problem with the "re-insert cassette" message. I did the same thing - dropped the camera gently from a foot and a half on a bed. It worked! When I close the inside cassette door I gently press the top left side until it catches (that is where the latch is located). I may have pressed both sides trying to get the door to close when it wasn't cooperating thereby causing the latch to fail to connect. Another cause perhaps was leaving the camera idle for a year without using.
  • 10,594 Answers
Hello Bob92116 & PenName,
Camcoder needs lapping of video head, because it became dirty and this can be done at nearest Sony repair shop. I think it doesn't cost much.
In my point of view, reason of this clogged head is your Old Tapes having enough amount of dirt on tape.
Posted on May 27, 2008
6ya staff
SOURCE:
How to play tapes not recorded by Sony Handycam DCR-TRV130 Digital-8 Digital Camcorder
It is my understanding that the camera won't playback those formats, timecode or not. There are VCR type units for the HI8 and other formats. They should be cheap on eBay now...
Nov 18, 2012 | Sony Handycam DCR-TRV130 Digital Camcorder
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
HI when I use my cam (sony handycam D8) in the play mode to read videos the tape turns but there is no vids and the time counter is --:--:-- means not counting even if I can hear the sound of the...
Try to use cleaning tape there is must be dust on video head. First use cleaning tape for 5 secound then play you tape if its not ok then use more 5 secound. After that check your recording tape hope fully it will work.
Oct 28, 2010 | Sony DCR-TRV270E Digital-8 Digital...
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony TRV460 D8-->Hi8 switching
I too was having a problem playing back my 8mm in my TRV460. The audio and video was both very glitchy. I tried what dyz66 said and rewound to the start of the tape,and then recorded about 10 seconds of meaninless video. After that the whole tape played nice and clear. Thanks for the idea. I believe from here on out I'm going to buy some new tapes to try and avoid this.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
Playback won't work
needs to be cleaned and possibly tension adjustments. most cases this will fit it but the video heads could need replacing.
Sep 14, 2007 | Sony Handycam DCR-TRV245 Digital-8 Digital...
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
470 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
