Question about Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
Chain oiler not working on my 235e saw - Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
  • dontbother10
    dontbother10 May 11, 2010
    I agree with tbirdfan but, When did you purchase this? Your manual (last page) says 2 year warranty. Before doing anything contact Husqvarna if it hasn't been 2 years. HTH Lou HusqvarnaUSA.comhttp://www.husqvarna.com/us/homeowner/su... Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode ? for use with IPL 06 1500198 06 = year produced ? 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week
    President:
  • 2,220 Answers
Manual de-mystification
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
HTH
Lou
Posted on Nov 13, 2009
  • 3,051 Answers
Hello there:
i would recommend if you are not familiar with disassembling the saw
take the saw to be repaired. If you have checked all of the little hoses for cuts or clogging and oil level
Also
There is a small plastic gear that runs the pump. that pumps the oil to the bar The teeth can break off the gear and ruin the pump
If you are able to fix things yourself, it is a $5.00 part.if you have the correct tools to fix this. ok?
I hope that this is very helpful for you
Best regards Michael
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
Tip
Checking your chain oiler
Chain oilers are a vital part of keeping your saw running well. No oil can even cause the chain to bind up. Over a period of time it can greatly increase the wear rate of your bar and chain reducing it's life. Chain oilers seldom go bad they just get clogged up with sawdust.
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
on Dec 05, 2009 | Garden
How to get chain guard off 235e husqvarna?
The chainbrake must be open, then turn the chain tightening handle counter clockwise. The side cover can then be removed.
Apr 26, 2014 | Husqvarna Forest & Garden #952802239 235E...
Where is the adjustment for chain oiler?
depending on the saw it may or may not have one. most home owner saws are not available with an adjustable oiler. if however you are sure it has one it is accessed via the bottom of the saw on the clutch side
Feb 10, 2013 | Garden
I have a husqvarna 235, my oiler has quit working. I pulled the clutch assembly & cleaner the oiler gear but still no oil, resavoir is full
If you spin the oiler with the when it is desmantled does any oil come threw? (if so then the drum may not be linking to the oiler properly) also check the screw that determins how much oil is coming threw is turned up. And check the filter in the bottom of the oil tank is not blocked
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Download file
  • Copy link address
hope this helps a bit
Apr 21, 2010 | Husqvarna Forest & Garden #952802239 235E...
Problems with the 350 husqvarna bar.
If all you say is true and when revved up the saw oozes oil with the bar removed, then I suspect the bar is incompatible with the saw. Has the bar been replaced? The oiler holes in the bar must align with the channel in the saw. Oiler hole placement is part of the reason there are so many different part numbers for bars. The mount is only part of the requirement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Husqvarna Forest & Garden #952802239 235E...
Oil flow not working?was below 32 degrees has this damaged anything
Your saw (Husky 235E) is not fitted with an adjustable oiler. The manual does not mention using a thinner oil with lower temperatures. If it was run for an extended period without oil it may have caused a little wear to oiler components. I would take it into a warm area, let it acclimatise, and test the oiler as follows (it will probably oil the surface it is sitting on; my Lady would not be happy if I oiled her table!):
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Manuals here:
HusqvarnaUSA.com
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
It is equipped with an outboard clutch, the oiler is below it. This will help you remove clutch parts.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
A phone call to your local Husky dealer for an estimate might provide a pleasant surprise. I might inquire just to get recommendations for using the nonadjustable oiler. It is not as difficult as it appears. Good luck. HTH
Lou
Jan 12, 2010 | Husqvarna Forest & Garden #952802239 235E...
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Oiler not working, need diagram to fix
HI. IF YOU GOT YOUR SAW NEW THERE SHOULD OF BEEN A DIGRAIM SHOWING YOU HOW IT WORKS. THATS THE BEST YOU WILL GET UNLESS YOU KNOW SOMEONE AT THE SAW SHOP BECAUSE THEY DON'T WANT YOU TO KNOW HOW TO TAKE THEM APART AND PUT THEM BACK TOGETHER. GOOD LUCK. JIMBO
Jun 25, 2009 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw Logo
311 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
