Question about Sanyo DP46848 LCD TV
The left side of my Sanyo DP46848 LCD HDTV is dark when the unit's first turned on. After 10-30 minutes, the whole picture is fine. What gives, it's just over a year old.
SOURCE: My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Posted on Nov 22, 2010
joeguest2
  • 2080 Answers
SOURCE: I have a SANYO DP46848,
This is likely a problem with your TCON circuit board inside the back of the tv.
The TCon board usually has 2 (or 4) very thin ribbon like cables running from connectors on the board to the actual LCD screen panel. Each ribbon controls one half (or one quarter) of the screen. If you are lucky, it's possible one of the ribbons came loose or is not making proper electrical contact with the connector on the TCON board.
If your tv is out of warranty and you are comfortable working safely with electronics then you may be able to repair this yourself with a few hours of screwdriver work. The ribbons may just need to be reseated in the little flip up connectors, or you may have to clean the copper at the tips of the ribbons gently with a pencil eraser to remove any oxidation.
If you are unlucky enough to have a bad TCON board or are not comfortable disassembling your tv yourself then you can bring it in to the shop and they can probably repair it for less than $150.
Good luck and please post back with how you make out.
Posted on Jan 25, 2011
  • 8457 Answers
SOURCE: Every day when I first turn on my LG HDTV model
The board that call the T-CON decoder board is dying this board job are decodering signal before it go to LCD screen panel.This T-CON decodering board sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Posted on Mar 02, 2011
  • 1779 Answers
SOURCE: DO THE SANYO DP42848 AND THE DP46848 LCD TV 2008
No boards in those models interchange with each other. Totally different.
Posted on Jun 16, 2011
homecompu119
  • 3 Answers
SOURCE: i have a sanyo 46" lcd hdtv model #dp46848. its
Solved: Over the course of time, the cheap plastic frame and stand starts to put uneven pressure on the LCD causing it to malfunction. I guessing this could be heat related. Definitely a design flaw. Remove the bottom of the stand and very slightly loosed the small screws around the back of the frame allowing the LCD to have some wiggle room. After I did this, it worked. It will still misbehave if you stress the LCD, but normally, it shouldn't. I am going to try to mount the TV using the rear VESA mounts & see if it will still work.
Posted on Mar 31, 2013
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
Sharp LED TV 3 years old stays dark on left side of screen for about 10 minutes after it is turned on. What could be causing this?
It seems to be capacitor{s}. Check the sharp website to see if there is any recall or special warranty on this unit.
Dec 15, 2013 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
I have a sanyo 46" lcd hdtv model #dp46848. its
i would say buy new as it sounds like your whole datata buffer on the rear left has failed
Mar 19, 2011 | Sanyo DP46848 LCD TV
Sanyo DP46848 has sound but no picture.
Tv turn now,have a flashes of picture a few sec.than dies have sound left only?Yes,than ur tv have a 2 long boards are dead that call LCD inverter boards.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 07, 2010 | Sanyo DP46848 LCD TV
I have a SANYO DP46848, after i turn on the TV after a few minutes the picture turns a blue/grey color. There is still a picture and sound, but poor picture quaility. Need some help?
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
Dec 07, 2009 | Sanyo DP46848 LCD TV
Sanyo 46 IN. tv DP46848. The left 1/3 of screen is dark
It is a common problem for this model of a Sanyo TV, it uses a Samsung or Chime LCD panel.
The problem is the data buffer IC soldered on the flat flex cable between the LCD panel & the buffer board that gets damaged or loose soldering. If you be able to fix yourself, you may find some videos on YouTube, it will show you how to fix the buffer problem.
Jun 01, 2017 | Sanyo Televison & Video
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Sanyo DP46848 LCD TV Logo
339 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
