Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
I am trying to connect my PC to my Aquos, but can't get sound transfered. I am using HDMI 4 connection and the earphone jack split into a left right plug for audio input on Aquos.
  • 405 Answers
Make sure that you select analog audio to work with HDMI video.
Sins no model (lc-******)was provided, it is impassible to give you step by step direction.
Posted on Nov 13, 2009
Testimonial: "Was not aware that I had ability to specify analog signal. Great advice. Thank you"
Trying to connect pc with hdmi cable have great picture no sound on TV Used HDMI imput 7 tried imput 6 with hdmi and audio imput from PCF to TV still picture and no sound any suggestions
Hi Scott,
On your PC, you'll need to go into the Control Panel --> Hardware & Sound --> Sound (Windows 7) and click on "Playback". Here, you'll need to change the sound settings to reflect the audio to be handled by the video card / audio chipset / HDMI jack on the motherboard. You should also check for other settings such as Digital Output that are usually associated with and HDMI jack on the card and not an analog jack.
As it is now (or is likely to be the case anyway) the picture is being handled by the HDMI on the video card / motherboard; but the audio is still coming from the the speaker jack(s) on the motherboard or audio card. Making the changes above will redirect the audio from the speaker jack(s) to the HDMI jack instead.
Mar 27, 2015 | Sharp 52"" aquos lc-52sb55u 1080p...
Sharp aquos audio input jack not working
That 3.5 jack only works when the TV input is selected for PC. Try an HDMI or Hi def cable connection to the TV
Dec 14, 2013 | Sharp Aquos Televison & Video
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
I use headphones from my nokia phone for my pc and they were worked great, but now i can hear the sound that comes from the right side on both speakers, and the sount that come from left i can hear on
If you look closely at the plug itself (the metal part which actually goes into the hole), you will see that there are either 3 or 4 shiny metal areas separated by some black plastic or some other hard substance. The shiny metal area is a conductor of electricity, and the black part is an insulator of electricity, keeping the conductors separate. Normal stereo earphones have 3 conductor areas, because that is all you need to send a different signal to each ear. Earphones that include a microphone, however, require four separate metal sections, because they need another separate conductor for connecting the microphone. They try to design the 4-conductor plug so that it can still be used in a 3-conductor jack (backwards-compatible), but it is not going to be perfect.So the headphone jack in your PC is designed to accept a plug with 3 separate areas, and will connect each of those 3 separate areas to the correct circuit on the sound card of the computer, but the earphones for your phone likely have 4 separate areas, unless I am barking up the wrong tree. You can typically connect another sort of microphone to a PC, but normally it is a separate plug altogether.So why did it work before, and not now, you ask? headphone jacks have very small, metal, moving parts that physically come in contact with the appropriate separate conductors when you insert the plug. Moving parts like this can change over time enough that(or can have dirt get inside them to the point where) they no longer connect exactly the same way that they used to, especially for plugs that they are not originally designed to connect with in the first place. Headphone jacks probably cost the manufacturer somewhere around a cent apiece (just guessing), so unless the manufacturer is one that will always pick the most expensive, robust components, what we are dealing with is a problem with a part that cost less than a nickel (maybe less than a penny, for all I know) and was not really engineered to handle a 4-conductor headphone jack. If you get a 3-conductor set of headphones, they will probably work correctly, but remember you get what you pay for, so the cheaper you go, the more likely they are to **** out sooner than later.
Feb 02, 2012 | Audio Players & Recorders
The left speaker or controlling speaker has no ... very little sound.. the right one is working. I have them hooked up to a computer with the earphone jack which splits into right and left jacks.
Right click on your volume icon at the taskbar, & open your volume control. Check if the Master Volume - "balance" is at the center!!
Check your speaker connecting cables are securely plug in.
Hope it helps.
Mar 31, 2011 | Audio Players & Recorders
I have an hp 2011x monitor. How do I connect earphones for sound ?
If you are asking about where to connect the earphones to the monitor, you can't. As far as I can determine this model monitor does not have an earphone jack nor built in speakers.
This is a great HD monitor, but you will have to plug the earphones into the jack (green plug) on the front (and/or back) of the computer to get the sound.
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Mar 05, 2011 | HP Computers & Internet
Hi there i am trying to connect a samsung lcd monitor to my pc via HDMI. i have the connection showing picture on my tv, however where i connect a 3.5mm jack from pc to tv no sound comes out. i have...
The connection to your tv is video only. You should hear sound coming from computer speakers. Unplug them and hook your stereo to that plug in.
Oct 04, 2009 | Computers & Internet
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32" Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Trying to connect a sharp aquos lcc3234u tv to pc using hdmi
it sounds like your computer isnt set up to send the signal out. try right clicking on your desktop and selecting a dual monitor setting. It should be found under graphics options or something similar.
Jan 24, 2009 | Televison & Video
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
291 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
