Question about Gateway FPD2275W LCD Monitor
GATEWAY FPD2275W 22" will show everything when unhooked from pc then reconnected but within seconds goes to a black screen. I have 2 and the other one works fine so it is definitely the monitor giving the problem.
  • 585 Answers
Chances are that some capacitors in the power supply have failed. some monitors are known for this. The parts are readily available, but they do solder in.
Posted on Nov 13, 2009
I have the 22 in. FPD2275w black lcd monitor 2006 and everything is dead no nothing what can I do?
Bad caps, be REAL CAREFUL when take the bezel out, you can easily damage the small ribbon cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Jul 26, 2010 | Gateway FPD2275W LCD Monitor
The Gateway FPD2275W TFT LCD Monitor the screen is black when my computer is up & running. I can briefly bring up the screen, and it shows my desk top, then changes to black. I have been trying to...
Hi!
The problem is not the setting on your monitor...The problem is the backlight inverter located inside the upper and lower edge of your screen..
It is busted. The backlight inverter is the light source responsible for the displaying image on your screen. If these were busted.. then the only thing you will see is black screen.
It is very risky for you to replace it by yourself if you don't have the knowledge and the right tools to open the back of your lcd..My suggestion is to bring your monitor to a credible technician to have your backlight inverter replace. if there is warranty for your lcd, please avail this.
Hope it help..
Much appreciated if you rate this solution..thanks..
May 26, 2010 | Gateway FPD2275W LCD Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
My monitor fpd2275w gateway turns on but the screen is black
mine does it too...it seems to be that the back light is not staying on...seems to come on full brightness for about 3 seconds then goes out, there are images...but no backlight
Aug 27, 2009 | Gateway FPD2275W LCD Monitor
FPD2275W No PC or On Screen Menu Display
Jul 28, 2009 | Gateway FPD2275W LCD Monitor
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Monitor goes blank after it comes on for two seconds
bad capacitors on the power board internal to the monitor they need to be replaced, let me know what you would like to do
Mar 22, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Acer Monitor will not function
Monitor is getting hot and cutting off. Try on another computer. Try another video card. If it does the same thing then it is BAD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
268 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
