Question about Burris Fullfield II Riflescope
Soon as it gets cold out it seems to want to get blurry
    Problem Solver:
  • 18 Answers
If your scope is fogging it has lost the nitrigon in it and you will have to send it back to the factory to be refilled and resealed. I would send it back to burris.
Posted on Mar 11, 2010
I had cataract surgery on both eyes over the past few months, Its now post opt since August. Now my vision is blurry now with floaters and redness. sometimes cloudy is this normal
i have had a look around the internet about this but did not get much info about it.most people are saying to get in touch with whom ever done the surgery on your eyes.
sorry i could not be of more help to you on this matter.
Oct 28, 2017 | Vision Computers & Internet
Non-zoomed pics are in focus but as soon as I zoom in, even slightly, pics get very blurry. What settings should I be adjusting, please?
M stands for macro.this is for extreme close so dont take photos with m displayed unless extreme close
Jul 06, 2015 | Sharp Cameras
My 2004 impala shuts of when cold but once u get the gas it runs fine whats seem to be the problem
You may want to replace the coolant temp sensor as these can cause all sorts of problems seemingly unrelated. Are there any service engine soon (check engine) or low coolant lights on?
Oct 17, 2013 | 2004 Chevrolet Impala
My Whirlpool does not get cold enough. It has 5 x
This means that the thermostat section is faulty as it seems to sense the temperature with an error.
When it is set at a higher level is seems that the circuit seems to get a wrong error and so cuts off. Also if the compressor is not pumping well or the gas is down the cooling will be low.
Try and see on the maximum setting if there is cooling and the point it cuts off, if this get you the best cooling and if the compressor shuts down on reaching this temperature. If so the control unit is a suspect.
Aug 24, 2011 | Whirlpool Refrigerators
1996 gmc suburban seems to get frozen in park in cold weather. pull real hard to break loose works fine when warm
SHIFTER CABLE WILL BE BROKEN SOON. CABLE IS BINDING IN IT'S SLEEVE, COLD MAKES IT HARDER TO OPERATE...
Nov 26, 2010 | 1996 GMC Suburban
Water pump
My estimate is that it's time to change the water pump because when they start leaking a little, it will turn into leaking a lot pretty soon. That's what i would do if it were mine. Rick
Apr 16, 2009 | GMC C1500 Cars & Trucks
The engine seems to overheat and the internal heater blows cold
The problem is your coolant level has gone too low check and top up when engine is cold, you will see the marks on the expansion bottle, if prob persists there may be an airlock in the heater radiator. keep an eye on coolant level or you will have cylinder head problems.
Jan 03, 2009 | 1996 BMW 318
Cannot Zoom in or out
I took the battery off and then put it back on and when I turned it on it worked fine! Thank you
Jul 03, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Fuzzy page continious.
Yeah I just read a tip. There seems to be a problem with the wave amp board, I will send you the engineering note. Sometimes though that encoder needs replaced and cleaning is not the total fix. The encoder may need replaced, but I found this also.
I just received this, this morning.
Failed Wave Amp
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Historically blurry print was caused by oil on the drum encoder wheel. This can be caused by the wave amp board. A cracked capacitor on the board causes the wave amp to produce a malformed amplified wave signal to the printhead. This in turn causes the printhead to eject ink at the wrong times, so the prints look blurry.
You can generally distinguish a wave amp problem from an oily drum encoder. The wave amp problem will usually be an infant failure. The printer will start producing blurry prints soon after it is installed and running. With a failed wave amp all prints will be blurry with no improvement. The drum encoder, on the other hand, may produce good prints and then bad prints and then good prints. Blurriness changes depending on how the oil is interfering with the encoder.
May 05, 2008 | Xerox Phaser 8500/DN Printer
Optics Logo
66 people viewed this question
Top Burris Optics Experts
Tom Chichester
james laughton
james laughton
RichardL
RichardL
Are you a Burris Optic Expert? Answer questions, earn points and help others
