Lg washer/ frontloader
Smell is real bad
  • 3 Answers
Take a hand towel soaked in vinegar, then run it around the rubber seal around the front of the door, making sure you get all the way under. Then run a load of whites with javex or vinegar. Always leave the door ajar after you are done washing, or that mildew smell will re-appear.
Posted on Nov 13, 2009
LG washer will not start
How to Fix an LG Front load washer machine that wont spin ...
? 5:32
www.youtube.com/watch?v=J11Thy0vW0Y
Nov 30, 2012 - Uploaded by Zack Nelson Diagnosing an LG frontload washer machine that wont spin. Also tells you how to get into the diagnostics ..
Aug 06, 2015 | LG Washing Machines
Tip
Bad smell inside washer
Every Frontload washer on the market today has a smell issue or potential to have one quite easily.In fact the smell problem has been there since these Frontload washers were introduced. The real kick is instead of recognizing the problem and addressing it some of the manufacturers have even started selling consumers cleaners to help reduce the smell problem. Yes they are profiting on the sale of cleaners, that deal with an issue they created. The closest they have come to addressing the issue is adding an extra cycle to your washer strictly for cleaning the washer. Basically you clean your washer so it can clean your clothes. Why didn't the salesperson tell you about the issue? Maybe because it was his first day, but probably because he was trying to sell you a washer.
Now all this said, is there anything you can do? First and foremost make absolutely sure you are using a HE (high efficency) detergent. Frontload washers use a very little amount of water and the HE detergent is not only concentrated so you use less but it is not as thick as regular detergent so it has a better chance of washing away clean. Concentrated detergent is NOT HE detergent and still may pose an issue if used. If you Don't know what HE detergent is, call the manufacturer, your grocery store, or the sales guy who sold it to you. On average you will never need more than 2 tablespoons per load. DO NOT go by the cap fill lines ever. These lines make the assumption everyone has the same water, load the washers the same and have equally dirty clothes. More is NEVER better in a Frontload. Bottom line is you want to make sure all the detergent is getting cleaned out of the washer after each use. If any remains it will start to deteriorate and deteriorating detergent can smell.
Secondly when you are done using the unit for the day, use a towel to dry off the rubber door boot and the inner door. Don't be afraid to pull the boot some to get as much of the water off as possible. The rubber is pretty thick and sturdy. And if at all possible leave the door open as long as possible to help what water is left inside the washer to evaporate. The washers have vents on the back but they do not work as well as venting on a top-load washer. Basically the water drops will collect in the bottom after usage and if the door gets closed that water can get stagnant, grow bacteria and even mold. These will also cause lovely fragrances to tickle your nose.
Finally if you want to try some of the washer machine cleaners they may help some to clean away any buildup that may be already inside the washer. However it seems silly to pay so much for a washer and have to continually maintain a problem that is caused by the washer with cleaners produced by the washers manufacturer. If you try and cut back as much as possible (2 tablespoons) on detergent, and allow as much water to be cleaned out or evaporate the smells will resolve themselves. A good test to use if you think you have a buildup is fill the washer on it hottest cycle with the drum empty. Let it wash around for a few minutes and just look inside and see if you see suds. Suds in the washer tells you soap is still in the tub somewhere.
on Jan 21, 2010 | Washing Machines
I have an LG washer that smells like rotten clothes. My clothes come out smelling real bad. I checked inside and noticed that the rubber seal around the door is holding moldy rotton gunk. It's not self...
Run a cup each of baking soda and vineger thru a hot wash. Might have to do this a couple of time if smell really bad.
Take out the unit where the liquid soap, softner, etc goes and clean by hand.
Soak a cloth in vinegar and clean the inside of the rubber around the tub.
And finally DO NOT LEAVE THE DOOR CLOSED IF NOT IN USE.
Oct 31, 2009 | LG WM2688HWM TROMM SteamWasher
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Mar 24, 2009 | Kenmore 22422 Top Load Washer
LG Frontload Washer Top Removal
take the 4 philips screws out the back of the top panel then push the panel back. good luck .
Jan 15, 2009 | LG WM-2277HW Front Load Washer
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
