Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT WFW9200SQ/A
Delivered from Best Buy. Tried to do the initial wash but get error code is F32.
After you start the machine in the Normal cycle, only a trickle of water & then the motor makes noise but the drum doesn't rotate. All the time "F32" is flashing. About 10 minutes later it powers off.
This code is not in the manual or the Whirlpool website.
Help. Thanks,
  • 3 more comments
  • nonhandygirl Jan 09, 2008
    front loading washer- trickle of water comes in -then nothing. drum does not rotate, no action. is there anyway to reset the control on button or recycle the water out of the washer? have pushed the end of cycle button for 3 seconds and 30 seconds, unplugged from the wall and restarted, pressed the pause control button-- no success, please help, advise, thx, all,
  • janeovo222 Mar 15, 2008
    Gorenje WA 162  P front load washing machine. Error code F32. After filling with water drum turns half circe (about 180 degree) and stops with F32.
  • zettyk Apr 26, 2008
    same problem here. I finally powered it off then it restarted by itself now with error code F28 flashing
  • kgraham39 May 15, 2008
    I too have this problem. Had my washer since January I think. Has been fine up until today. Used it last about 4 days ago and it was fine. Called Whirlpool and they are sending out a repairman tomorrow. I'll let you know what I find.
  • cybersony200 Apr 26, 2009
    I got my Brand Spanking New Whirlpool Washer model# WFW9200SQ/03 and just like the other people stated, it injected a few squirts of water and then it stoped with an F28 error. At first, it tried to start the cycle at 50 minutes and immediately it squirted a little water and stoped right away; at minute 47, and after complete silence, it emited error F28 (Not listed on Whirlpool's instruction manual book). Yes, whirlpool will send a technician in TWO DAYS, all I have to do now is sit around with dirty clothes and then miss a day of work (their estimated arrival time is from 8:00AM - 5:00PM).
Does anyone have a repair manuel for the Whirlpool Duet WFW9200SQ they would be willing to e-mail me? My address is eod5150@gmail.com I would be willing to kick down a few bucks if you have a paypal account in need be. Thanks
Posted on Aug 22, 2010
I went on line and found a manual that has error codes. It only has codes 1-15 and a few other alpha codes. Type in whirlpool duet washer manual and you will be sent to a window displaying a PDF. Hope this helps.
Posted on Feb 06, 2010
We just had the same problem with ours. We unplugged the unit from the wall and replugged it in. This worked so it may have rebooted the computer. Hope it is successful for you as well.
Posted on Dec 22, 2009
    President:
  • 1,294 Answers
Plug off the wall. Close the wall faucet and check the hose & small screens on it. Open the faucet to see if the flow and pressure is good (keep bucket handy). Refit carefully, try machine. Code is nt seen anywhere as you said.
Posted on Jan 08, 2008
4 Suggested Answers
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
duby1990
  • 370 Answers
SOURCE: How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Posted on Nov 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: WHIRLPOOL DUET SPORT WASHER FLASH FAULT CODE F28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Posted on Sep 28, 2010
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Error code F-11
F11 Motor control unit internal failure MCU board failure or broken wire.
Check your wiring harness for a loose connection or a break in the wireaa6d6a5.jpg
Tech sheets for wfw9200sq
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 27, 2010 | Whirlpool Washing Machines
F35 code
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet has just come up with F32 error on display. Any ideas please?
I checked my code book and there is no f32. you should have a code tech sheet. this would be located on the bottom panel insid the washer. Check to see if they have a f 32 code.
Nov 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F32 comes up when we just installed our new Whirlpool Duet Washer WFW9200SQ.
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
May 01, 2008 | Whirlpool WFW9400S
Whirlpool Duet GHW9150P Front Load Washer Logo
1,476 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
