Question about Garden
Eb 431 has been running great! Started it
Eb 431 has been running great! Started it recently, put it down to move some thing and when I went back to it it had stalled out. After that I could not get it started again. There is no spark to the plug, what should I check first and thenin order till repaired?thanks
  • 486 Answers
No-start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 13, 2009
98 Suburban will not start
Check for spark when it won't start. If no spark, it's an ignition problem-suspect the crank position sensor. The computer won't cause spark from the coils if the crank sensor gets hot and fails.
Nov 23, 2013 | 1998 Chevrolet Suburban
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
Recently on my 1990 ranger, I went to start it up for the first time of the day. started and back fired and died. under the hood found a rubber line that came disconected to a part that blew air out , its...
That is a vacuum hose do you have anything to plu git up The brake hose you are talking about put that back the reason it idles rough is from excessive false air entering the system. Youll need to restore the hoses back is there a hose diagram on the hood if there is follow it or give me the engine size ill draw it
Apr 23, 2011 | 1990 Ford Ranger SuperCab
Our 1998 Ford windstar has went all EXORCIST in dash board etc.
at the minimum, since you mentioned all the idiot lights coming on, your alternator is fried. have someone put in a new alternator. if it's still acting up, have someone go over the computer.
Jun 10, 2009 | 1998 Ford Windstar
Need new codes for Eurovox in south Dublin , which provider am i?
dodo press menu then yellow button put 5401then down to 1st line
b0 b8 4f 04 e6 5f 87 80
ac eb ec 07 46 49 d2 eb
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Roomba just runs in small circles
i just recently had someone bring in a roomba discovery and all it would do is stay in a tight 4 tile area and go in circles. battery was fully charged and all bumpers were clear.
i took a can of air blast for cleaning computers and blasted the area on the bottom underneath the sensor and watched as several dust bunnies came flying out.gave it a few more blasts for good measure and put it back on the floor and hit power then clean buttons.
thing went in same tight circle for 2 passes then the circle got bigger for 2 more passes , blue light indicator came on and it made a straight line dash across to closed door and started following the edge and criss-crossing the room.
called the owner back in to test and it repeated the same moves when she started it and all appeared to be working normal again.
Aug 13, 2008 | iRobot Vacuums
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
