Question about Sharp AL 1631 Copier
I have a Canon 6012. It just stopped one day. A red barrell like light is on (it's the top light) then in the screen where it shows the number of copies being printed it shows CC.
    Sergeant:
  • 329 Answers
Drum needs replacment. There is a small board with chip on new drum. Getting hard to get for 6012...
Posted on Nov 19, 2009
Alcatel one touch sonic wont turn on....
return to seller would be my option
Dec 26, 2014 | Alcatel Cell Phones
Plug tv in and shows green light for 5 seconds and then blinke red for 5 seconds stop for 3 seconds and red for 5 seconds and repeats
I HIGHLY recommend using LITHIUM Batteries..... in the higher capacities for a Digital Camera....They seem to last a lot longer than Alkaline.
In my Compact Canon, I use rechargeables in a High capacity, with Lithiums as a backup for when I am out somewhere.
Format the cards IN THE CAMERA..... as anywhere else they could be that tiny bit out.... I am not 100% sure why but it does happen.
and if any problems when you connect to a Computer.... try a new Cable......
Good Luck and good shooting
Jun 01, 2014 | Kodak EasyShare M550 Digital Camera
Kitchen tap just turns wont stop or start had to shut down with stop **** taps are plastic on top with red and blue think pre 1980
sounds like the splines in the tops have worn out
Prize off top red/blue insert u should see a screw in the middle - tighten
If tops still loose remove screw and prize up the plastic top. Hefty spanner on what's left [the tap barrel ] To counter twisting underneath - hold tap with other spanner/ wrench remove barrels and replace with tap reviver kit from local merchants
Oct 08, 2009 | Home
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
Jun 18, 2009 | Canon BubbleJet i560 InkJet Printer
MY HARMONY ONE TV CONTROLER STOPPED WORKING. THE KEYS AND THE SCREEN DONT WORK. SCREEN SHOWS "HARMONY SAFE MODE!" AND A SETIES OF ASKI NUMBERS KISTED FROM A. TO E. oNE SINGLE RED LIGHT FLASHES CONSTANTLY...
All you need to do is updaye the firmware.
1. Connect the remote and launch the software
2. Click 'Downloads' at the top
3. Click 'Firmware'
4. Update the remote
May 12, 2009 | Logitech Harmony One Advanced Universal...
Copier will not print, pyramid light comes on
that light indicates that you are out of toner
May 02, 2009 | Office Equipment & Supplies
Lens error
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
Oct 23, 2008 | Canon IXUS 860 IS Digital Camera
Philips 50P8341 green light
I believe its the vertical output IC. Diodes would tend to blow fuses . I would replace the vertical output and see if that takes care of the problem.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Sharp AL 1631 Copier Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
